Model X 75D / 90D 0-60 mph acceleration video
Frogwheels
30
23
Hong Kong
I've scoured YouTube but couldn't find a single video of the Model X 75D or X 90D accelerating from 0-60 mph / 0-100 kmh, only clips of ludicrous X P90Ds.
I'm putting together an Excel chart with acceleration curves for the various models based on acceleration videos.
Can someone with a X75D or X90D record the speedometer during a 0-75mph / 0-120kmh (or higher) run and share it?
Frogwheels
30
23
Hong Kong
What's wrong with the numbers that Tesla publishes on their website?
Because those numbers only mark a single point on this chart:
TSammy
29
9
Georgetown
The problem is that all your timings will be off by the extra milliseconds that it takes to convert to metric from: "one, one thousand, two , one thousand, three, one thousand, etc.
Frogwheels
30
23
Hong Kong
If you trust Tesla's Speedometer, then the measurements in the above chart are quite accurate, as the timings were measured frame by frame in Premiere.
Main Problem is determining the kickdown point at the start, although there's usually a spike in the audio track when the foot slams the accelerator. That adds maybe 100ms uncertainty to the whole curve as some slam harder and faster whereas some are a bit more gentle. Also add +-50ms variation for each point as the Speedo's refresh rate is a bit slow.
But if, for example, you want to compare different models on how long they'd need to go from 50km/h to 90km/h for an overtaking manoeuvre, the error would only be +-50ms.
It's sufficient for me to get a rough, but handy comparative overview over how all the different models actually stack up against each other in the real world.
