Model X 90kWh battery pack degradation
HostileHarry
276
204
Chicago
March 2016; vin 274.
about 78K miles; just replaced MCU under extended warrenty.
according to teslafi, AC charging 1906 charges at 40 locations, 16,795kWh; Supercharging 409 charges at 209 locations, 11,273kWh.
Thank you for the data. A couple of questions for you:
What kind of supercharging speeds are you seeing?
what is your current 100% rated miles?
are you noticing any noises when charging above 80% of heating/cooling fans that S 85 owners are seeing?
Reactions: racpuc
gjunky
Trifecta: Solar and both cars are EVs
Mar 26, 2012
1,247
405
Scottsdale, AZ
Just charged our x90d, delivered June 2016, 54k miles, Vin 05xxx
90%=212 or about a 9% degradation.
Our Model 3 with 23k miles has hardly any degradation
Patrick0101
161
174
Oregon
3-year report
z168
107
24
SoCal
Picked up a 12/2016 MX today with 22K miles. On my first charge it only went up to 225 miles full charge.
The MX came with battery warranty till 2024. Would this be something I could immediately claim this under warranty?
Pale_Rider
673
749
Houston, TX
Only if they find there is an issue with the battery. Normal degradation is not considered a warranty issue.
Reactions: MP3Mike
Pale_Rider
673
749
Houston, TX
Got it. How bad is 225 miles full charge for a 2016 battery?
It’s about 12% loss, which isn’t great for that many miles, but hopefully it will stabilize there and not really lose much more. You can always ask them to check the battery just to be sure there are no internal issues. Did you buy it directly from Tesla?
tedsla
Mobile Member
Oct 12, 2014
41
11
Florida, Utah and New Hampshire
Status report on a May 2016 MX90D on 2020.4.1 with 90K mile:
A normal 90% charge is 212-213 Miles. This seems to be about a 8-9% degradation. It will supercharge at max of 94KW when SOC is 47-51% then drops as SOC increases. This to seems to be what others with similar vintage experience.
neverdone
200
480
Loveland, CO
yeah. No one seems to belive me that this has occured.
I have a Tesla Wall Connector; 18 feet. I believe the reason for the lower charge at 30A is due to a degraded Tesla power cable. The Tesla mobile service guy says that the cable can degrade and you will get lower power. He said you used to be able to purchase just a replacement cable; but no more. I have had the wall connector for almost 4 years. I get full 40A at my daughters house with a Tesla Wall Connector, and full 40A using the Mobile Connector.
TESLIFT
22
Canada
My wife’s May 2016 X P90D with 30,500 miles, is now at 207 miles @ 90%. Not good.
Could be because of early version.
Mine is a MX 90D April 2017 - brand new it was 262 miles at 100%, now after 47k miles it has 251 miles. I lost 9 miles in almost 3years... not too bad...
Vaillant
250
263
Sunnyvale, CA
I’m in the market to pick up a used X and the 2016 model year 90D is what fits in our budget. Does anyone know what month the cutoff is (about) to get the improved battery chemistry?
Also, I’ve been emailing the Tesla used car sales person and he says that they don’t do any battery capacity checks as part of their inspection. I suggested that charging to 90% and recording the rated miles or, at least, comparing the rated miles to charge % for an extrapolation would be a simple thing to do and very helpful.
forkee
770
957
Southern California
I'm always mystified with everyone's concern about battery degredation. I charge my P90DL X (4/2016 build) at home up to 80% (approx. 205 miles), then plug it back in when it gets under 50 miles. No worries about having lost a few miles over the past 3 years.
If you have as poor range as mine, you would also be concerned
2016 P90DL w/49k - 100% @ 227 miles :oops:
1 year later
Reactions: ohmman
