Model X - Aluminum Corrosion & Pitting
Discussion in 'Model X' started by adschlec, May 20, 2020.
  1. adschlec
    adschlec Member
    Westminster, CO
    Has anyone seen this kind of corrosion and pitting?
    I first found this on the driver's door of a May 2016 built X.
    After consulting others on FB, I found more corrosion under the spoiler on the passenger's side.
    Question:
    I would appreciate hearing about other's related issues, when they occurred, and how Tesla dealt with it.
    TIA!
  2. adschlec
    adschlec Member
    Westminster, CO
    Update!
    Littleton, CO service center has agreed to address the door frame corrosion at Tesla's cost "as a courtesy" but not agreeing that this is their responsibility (May, 2020).
    The spoiler is TBD.
  3. Simon_Emes
    Simon_Emes Member
    Vienna
    Have it on the spoiler. Mine is out of warranty, so i am looking to find a replacement or manual to have it fixed
  4. adschlec
    adschlec Member
    Westminster, CO
    FYI, a recent thread on the FB Model X owners group found several more people who have reported this. I encouraged them to add their info here as well.
    It looks like Tesla has been inconsistent in addressing it.
    At the very least, please consider reporting to NHTSA:
    File a Vehicle Safety Complaint | Safercar.gov | NHTSA
    Also, you may have luck with Tesla by being persistent and showing that other vehicles have had similar issues and been repaired at Tesla's cost.
  5. mxnym
    mxnym Member
    Bloomington, IN
    Isn't there a separate longer term corrosion warranty at least in the US due to national mandate? I mean, unless they didn't have to provide that warranty because "it's aluminum" or it doesn't "count" because "it's not rust," I'd expect corrosion to be covered under that warranty.
  6. Snowhound
    Snowhound Member
    Pa
    I just found the same thing on my spoiler last night and made an appointment for Monday. Came here to see if it's common. Mine is also a 2016 X. I had 20 miles remaining when I made the appointment so still under warranty......but not once I get there. Hopefully, it goes by when the appointment was made.
  7. adschlec
    adschlec Member
    Westminster, CO
    How did this work out for you?
    If repaired by Tesla, when and where?
    Could you share your VIN or something they could look you up by?
    I'm now getting pushback about the spoiler.
    Thanks in advance!
  8. Gaston
    Gaston Member
    Netherlands
    Found out today that my 2017 Model X has severe corrosion on the bottom side of the rear spoiler.
    Will contact Tesla, but am wondering how this worked out for others. Would think that this is a warranty case for a 3 year old car. Is it?
  9. Gaston
    Gaston Member
    Netherlands
    I should add that my mileage is over 50.000 miles, so the warranty is over.
    Yet, a 3 or 4 year old car should not have corrosion like this. How does Tesla handle these out of warranty cases on young cars?
  10. vthreee
    vthreee Member
    Sugar Land
    i reported this on my used model x, the service center it was due to a wrap on the car... made me kinda upset... the car is wrapped now, but it hasnt ruined any functionality for me. i just hate knowing its there.
  11. Gaston
    Gaston Member
    Netherlands
    While it has indeed not ruined the functionality of the rear spolier, it seems a matter of time and that thing will actually fall apart. The corrosion at the bottom side is all over the place, and the spoiler is starting to show corroded spots on the easily visible side-parts too.
    I actually think many Model X owners are not aware of the corrosion, as you have to look under the rear spoiler.
    So, anyone who's reading this, and your Model X is over 2 years old, you may as well check it out. Please don't be mad at me if that will ruin your day. It did mine....
  12. Bigriver
    Bigriver Member
    Pittsburgh, PA
    I checked under the spoiler of my Sept 2017 model X and really only found water spots. I felt carefully over the entire surface and it is very smooth, with the exception of a slight rough edge of the brake light assembly. I will have to check it further under better lighting. Looking for little things to be sure to address before the warranty is done in 8000 miles or 6 months.
    With this type of thing it always leads me to wonder who ends up with the issue and who doesn’t and why.
  13. MasterT
    MasterT Member
    Home
    I too had spoiler underbelly corroded on my 2017 X, fixed under warranty in June 2020
