Model X Battery Charge Questions
GaryBowler
53
7
New York City
1. Is it okay to fully charge the battery the night before if I'm planning to drive locally all day the next day?
2. While charging, should running the A.C., heat, or other accessories be kept at a minimum?
Much appreciated!
TexasEV
7,640
8,464
Austin, TX
1. There’s no reason to charge to 100% if you’re only driving it locally the next day, unless you’re really needing that range for local driving. Try to stick to 90% charge for local driving, but it if you really need the 100% range then charge so it finishes soon before you start driving.
2. No problem running anything while charging. It’s called using “shore power”, where the energy to pre-heat or pre-cool the car is coming from the wall, not using up the battery.
David99
4,850
7,021
Brea, Orange County
Much appreciated!
Fully charging (100%) before a longer drive (local or long distance) is perfectly fine. If you need the range, use it by charging to 100%. Charging to 100% every day is a little more detrimental to the battery. If I know I need to drive more than 170 miles the next day I charge to 100% the night before. If it's less than that I only charge to 90% or 80% depending. But keep in mind, winter driving uses more energy.
You can use the heater or AC as much as you like while charging. There is no negative effect in any way. It takes up a part of the energy so charging will take a little longer. Worst case scenario: in extreme winter conditions when the car is cold soaked, the heater (and battery heater) will extend charging time by about 30-50 min. That's an extreme case, though. In most cases you will hardly notice a difference in charge time.
Reactions: WINGIT
GaryBowler
53
7
New York City
Very interesting! Was not aware of this phenomenon. Thanks again!
Reactions: WINGIT
