Model X Brakes
Hello,
I have a 2017 Model X P100D. Just curious if the following Brembo kit for my rear fits: KT00410 – Brembo Store USA
The rotors in the kit have the same diameter and thickness. However the break pad thickness in the kit (14.7) is much thicker than the spec in my on-screen manual (9mm). Is that a problem? Presumably not because its sold as a kit, but Im clueless on this.
Also, if anyone can recommend an aftermarket brake/rotor for the rear it would be helpful - presumably I have the Brembo Single Piston Rear Caliper?
Thanks
