Model X Car Alarm Going Off
Discussion in 'Model X' started by TWBC, Jun 19, 2016.
Tags:
  1. TWBC
    TWBC Supporting Member
    Galveston, TX
    Has anyone had an issue with the car alarm in their Model X? Mine started going off at midnight and has been going off every couple of hours ever since. I have the BlackVue dash cams and no one is around the vehicle. I called Tesla and they are sending the logs to the Service Center.
  2. pchan
    pchan Member
    Boston, MA
    #2 pchan, Jun 19, 2016
    I have never heard my alarm goes off ... In fact, even when there is a passenger inside and I walked away with autolock, nothing happens. I don't think there is an interior sonar detector. Maybe will try to open the door from inside and try to trigger it.
  3. EldestOyster
    EldestOyster Member
    Moonlight Beach
    I saw a post a few week back, in which the window was lowering and raising again by itself. Since the window action is triggered by closing the door, there may have been sensors involved. A service center visit was suggested. Of course, I can't find that post now.
  4. Spidy
    Spidy Active Member
    EU
  5. EldestOyster
    EldestOyster Member
    Moonlight Beach
    I see, in my previous post (that I can't edit?), I completely left out the connection that lowering the window with the car locked sets off the alarm. The OP actually watched it do this.
  6. bluetees
    bluetees New Member
    4947 Concannon Ct
    Yes. The same incident occurred at midnight as well. Responding to my Model X alarm (parked in my garage), I pressed the fob which opened the car and stopped the honking.
    Satisfied I solved the problem, I returned back inside only to have the alarm triggered again minutes later I called the support line who indicated they would send a copy of the log to my local service center.
    My phone also indicated the alarm had been triggered (twice).
    Kind of creepy...
  7. Gol4
    Gol4 Member
    San Jose, CA
    This happened to my two week old MX 3 times last night.
  8. Gol4
    Gol4 Member
    San Jose, CA
    Update: Called customer service and they are having the logs sent to service center and "someone will call me back". This needs to be sorted out soon. I'm going to have a a tough time explaining to neighbors why its the swanky new Tesla thats causing all the commotion. The alarm went off at 11pm, 4am and 6am inside a locked garage.
  9. gmtom1
    gmtom1 Member
    Honolulu, HI
    It could be your door latches failing. I had an intermittent problem where the passenger door would randomly open (the door stays closed, but the latch triggers) even when driving. It's enough to set off the alarm. My local SC checked the logs and found the issue and replaced the latch.
    • Informative x 2
  10. CTsla
    CTsla New Member
    Ca
    Has this issue been resolved for your Model X yet? Something similar started happening with my Model C at 3am-a series of intermittent honks occurred over about thirty minutes. The car is parked in a locked garage. I called the service center and was advised to power the vehicle off. It seemed to work, but I'm hoping by this issue won't repeat again.
    -Sleepless in CA
  11. gmtom1
    gmtom1 Member
    Honolulu, HI
    Door latches were replaced by the service center and I haven't had any phantom alarms or unexpected door openings since. (Knock, knock).....
  12. ValueAtRisk
    ValueAtRisk New Member
    Hartford, Ct. USA
    My MX, delivered 3/10/2017, began to have this problem. Passenger door is closed, but display shows an open door. Last night, and twice today, the alarm went off. It appears Tesla still hasn't resolved this latch issue. I still love the car, but this issue was around back in June 2016. I'm a bit disappointed Tesla hasn't resolved this pre-build yet.
  13. ValueAtRisk
    Hartford, Ct. USA
    Have you had any issues with the latch/alarm since the fix? How long did your X stay at the SC?
  14. Gol4
    Gol4 Member
    San Jose, CA
    In my case, the latches were replaced about 2 months ago and I have seen the issue since then. They kept the X at the service center for a day for this and a couple of other minor issues.
  15. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    I'm seeing the same thing. Very frustrating. For me, it is the driver's side door. Last night the alarm went off and App showed the driver's door open. I went down to the car; it was locked and the door was closed. So, I opened and closed the door, set the alarm again, checked on the App that the door was closed, and went back to bed. A few minutes later, the alarm went off again and App showed driver's door was open.
    I'm getting frustrated with these front doors on the X. Everybody is worried about the rear FWDs, but for me those have been rock solid. But, I'm getting problem after problem with the front doors. The auto-present just dings the car next to you. They don't work on a sideways slope (worse, half way through closing on an uphill slope, they give up and swing fully open - dinging the car next to you). And now, they can't tell if the door is open or closed.
  16. Plan B
    Plan B Active Member
    PDX
    Cant the alarm, or horn be disabled from "settings" or "controls"
  17. vandacca
    vandacca ReActive Member
    Hamilton
    Can someone please record the alarm going off and post it? Is there a fairly easy and non-destructive way to trigger it? Mine has never gone off and I'm worried that it won't go off when it needs to.
  18. thimel
    thimel Member
    Leave the driver's window down. Exit the car and lock it. Leave your fob far from the car, so the car won't auto unlock. Go to the car, reach in through the window and open the door using the interior handle. The alarm will sound. Now fetch your fob and double click the top to unlock the car and turn off the alarm.
    • Informative x 2
  19. gmtom1
    gmtom1 Member
    Honolulu, HI
    My X was at the service center for a day (not overnight) and they replaced the offending door latch plus a couple of other minor issues. Not one issue or false alarm since the replacement.
  20. mohanman
    mohanman Member
    Michigan
    Mine did that ..alarm going off all by itself at night every couple hours.. was the door latch on the right passenger door. A ranger came and fixed it quick.. in case happens to someone else.
