How are they powered?I had a blackvue 650 installed. No power in the mirror box. Had to go behind the dash. There is also no room in channel glued to the windshield, so power and data from rear camera have to run next to the channel. For now, they are glued to the windshield, but the installer is working on a channel to glue next to the existing channel. As they are, you don't even notice them unless you look for them.
I'm really interested in seeing the rear camera cable glued next to the channel on theThank you Sir, could you please post some pictures of the install. It would be most appreciated.
I have the backvue mounted just below the mirror box. The mirror is lower than the box so the blackvue hides well behind the mirror.I want to install a blackvue 650 with three questions...
1) I understand that the mirror box houses a rain sensor and a camera for auto pilot. If you mount the blackvue in front of the mirror, does it interfere with the camera?
2) If you wire it switched, would it defeat the parking mode?
3) Because the blackvue has wifi people say you can use the car screen to view the cameras. I thought video is locked out.
I am planning to have it installed with the Power Magic Pro for park mode. I had heard that the BlacVue DR650-2CH could take a 128GB card but appears limited to 64gb. Is there a product number?I have the backvue mounted just below the mirror box. The mirror is lower than the box so the blackvue hides well behind the mirror.
Yes, if switched, the parking mode would be useless as the camera would power down as soon as the car did.
The blackvue is wifi to the blackvue phone app only. It has no interaction with the car display.
Following this post. I expect my Model X to arrive in about a month and I'd like to add a dash cam system. Any more advice or experience would be helpful. I'm still trying to understand which system will work best and how they've been installed.
I installed one on my MS last weekend on my own. I'll be installing it with a professional installer on my MX this coming Friday. I plan to run the cables along the existing channel.
I will post a how to as well.
Wish me luck! Lol
