Model X door reopening when walking away
Discussion in 'Model X' started by Enz295, Feb 8, 2018.
Tags:
  1. Enz295
    Enz295 Member
    Redondo Beach, CA
    Does anybody has that issue?
    You close the driver's door, start walking away, and it cracks open almost immediately.
    This does not happen all the time. But now it forces me to stay away from the car to make sure the mirrors will fold and the car will lock. Annoying...
  2. Merrill
    Merrill Active Member
    Sonoma, California
    Same for me, very intermittant but also the auto open only works when you come from the front toward the drivers door. If you come from the rear of the car it never auto opens.
  3. chadcristi
    chadcristi Member
    Lakewood, CO
    Same here. I’ve come out on two occasions and the driver’s door is open slightly. Seems like it has done it when I close the door manually and walk away toward the front of the vehicle. My guarantee has been a triple tap of the top center button on the keyfob. This ensures the doors are all closed and causes the feature that opens on approach to disable momentarily giving me time to get away.
  4. hiroshiy
    hiroshiy Supporting Member
    Tokyo, Japan
    I use automatic doors every day and so far no issues. You all may want to visit Tesla SC to check sensors.
  5. Martin VanB
    Martin VanB Member
    Canada
    Happens to me too, It started after a software update.
  6. psgabin
    psgabin Member
    livingston, nj
    on occasion sometimes but I felt it was key in my pocket getting pushed against by something
  7. AnxietyRanger
    AnxietyRanger Well-Known Member
    EU
  8. chadcristi
    chadcristi Member
    Lakewood, CO
    #8 chadcristi, Feb 11, 2018
    Key fob in the pocket has definitely been an issue. My Dad called me this morning stating that his FWD opened unexpectedly when he was standing outside of his Model X. His solution is to start carrying his key in a different pocket. I do not believe these unintended openings are a result of defective sensors or hardware. The automatic opening doors on MX are unique and do take some getting used to. For example, if you have the automatic door feature activated, you learn to avoid walking past the driver's side when you simply want to walk past the vehicle. Otherwise, by design, you are greeted with an open door each time. Once you experience and master the use of these doors, however, you really feel like something is wrong when you drive a car that doesn't have the feature.
  9. chadcristi
    chadcristi Member
    Lakewood, CO
  10. vandacca
    vandacca ReActive Member
    Hamilton
    After almost 2 years of ownership, this just started happening to me last month (3 incidences so far) after the recent OTA update (4.1). This appears to be the exact same thing that happened to Elon Musk on stage at the Model-X reveal in Sept 2015. Feels like an old bug. I'm sure it'll get fixed in an upcoming OTA update.
