P90D
The presentation mentioned the default front door opening is 45 degrees "when enabled" so it's something you'd turn off (and hopefully will have a GPS and even time-based rule to avoid continually presenting like a cat in heat every time someone walks by ...) It also only activates from the angle of approach (not from the front) and uses through-metal proximity sensors to limit the angle before touching most obstructions. Parking next to a tall curb or storm gutter could be a problem. It wasn't clear if the sensors map the full space of just certain areas where the door might make contact.
The obvious thing being, while the Falcon doors won't ding the adjacent car, the oaf that parks so close will already have dinged the hell out of those long door panels on the X ...
