Model X Emergency Response Guide
Discussion in 'Model X' started by gde_eu, Dec 17, 2015.
Tags:
  1. aija SigX 649
    aija SigX 649 Winged Lion
    PA/NJ
    I suspected that the rear HVAC may be optional ..opined in another post that it could be one reason for delaying the 5 seater variant (requires additional engineering/regulatory approval/etc.)
    Interesting observation about the frunk - made a mental note to look into this a bit more.
  2. GregRF
    GregRF Squirrel Power
    Perhaps the model shown in the diagram is the non P edition? I believe the S70D and S85D use the same motor front and back.
  3. hockeythug
    hockeythug Active Member
    Minnesota
    That's what you call a bad day.
  4. MrBoylan
    MrBoylan Member
    New York, NY
    I call it "Risky Business." They should do remake with a Model X playing the part of the Porsche! :)
  5. stopcrazypp
    stopcrazypp Well-Known Member
    Depends on if the tow hook cover also needs an internal release from the cabin.
    Edit: looking at latest Model S manual, it seems the newer versions are also accessed in a similar way on the outside without needing a release from inside the cabin.
    From a emergency standpoint it makes sense, since chances are that in a serious accident, the emergency responder may not have cabin access.
  6. S'toon
    S'toon Knows where his towel is
    AB
    Bonnie will on Sunday.
  7. Ubbe
    Ubbe Member
    Gothenburg, Sweden
    Yes, it makes perfect sense as first responders need access to the loop that's under the hood. So if Tesla had located the loop somewhere else the outside accessible frunk manual release would be unnecessary. But the loop location is probably a carefully selected so it is easily accessible but still protected from crash damage.
    Do the alarm sound if the manual release is activated?
  8. RossRAllen
    RossRAllen Member
    St. Helena, CA
    Good to have this guide, and very informative. But, how do first responders get access it? Tape it to the roof?
    99.999% of first responders won't know all these details, most of which are very safety-oriented to rescuers and pax.
  9. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    I think there are websites and apps that have information for all vehicles.
    Example: Tesla Motors - Electric Vehicle Safety Training
  10. RossRAllen
    RossRAllen Member
    St. Helena, CA
    Thanks, and good to know. I hope responders know to look for and use the information. It somehow seems unlikely to me that someone in a racing fire truck is Googling Tesla Model X and looking for safety information.
    There's a lot of critical safety information in the X Guide. Responders can't go cutting their way in without hitting something that could pose a safety problem to them or pax.
  11. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    There are options. First there are some pretty good iPhone apps that have captured the main features of most late model cars on. The extrication specialist usually takes a peak at that as soon as we have VIN to go with. Just takes a few minutes to get the salient points for air bags, cables, power, hydraulic lines and other features needed for safety or ease of tearing the car apart.
    In some cases some have full computers with all the PDF's loaded and again searchable by VIN or there is an app to decipher VINs too that helps hone in on make, model, year, features
    And they if you work in a urban area you have probably encountered most of these cars either in training or in actual field work, or have access to someone who has.
  12. EarlyAdopter
    EarlyAdopter Active Member
    Redmond, WA
    I wonder if that rear HVAC unit is part of the "bioweapons defense mode" option.
  13. WentOffGrid
    WentOffGrid Member
    Warwick NY
    Yes that would make sense as it is optional
  14. Warrenbonz
    Warrenbonz Member
    Florida
    The rear HVAC comes with the 6 and 7 seat configuration options but not the 5 seat standard configuration. I don't think it has anything to do with the "bio weapons defense mode"
  15. J1mbo
    J1mbo Active Member
    UK
    Interesting that they call out the optional rear HVAC but not the main one. Surely the risk is the same?
    Also, wonder how this works with "bioweapon defense mode" assuming the filter is in the front of the car - maybe the rear HVAC is deactivated when the filter is in use?
  16. EarlyAdopter
    Redmond, WA
    How do you know this? It would make sense, I just haven't seen that stated anywhere.
  17. ModelX
    ModelX Active Member
    Utah
    When you are in the design studio that is listed to the side.
  18. goneskiian
    goneskiian Active Member
    Bellevue WA
    People are speculating that this is the case because both the 6 and 7 seat option boxes have "Rear air conditioning and heating system included." in them but the 5 seat option box does not.
  19. goneskiian
    Bellevue WA
    I was wondering about that too. Might require two hands! ;-)
  20. dwebb66
    dwebb66 Member
    Ladera Ranch, CA
