Model X Energy Consumption
vgrinshpun
5,886
22,789
PA
I was pondering the same question, particularly what is *rated* Wh/mile as compared to MS rated Wh/mile (300 Wh/mile).
vgrinshpun
5,886
22,789
PA
Actually, different Model S have different rated Wh/mile. My Model S 60 was 287 Wh/mile (IIRC), the P85D is 304 from what I can tell.
Yes, of course you are right, I was talking about my car (P85+ - without actually mentioning it :smile:). Hopefully some of the new MX owners can chime in.
Roamer
278
132
Mesa, Arizona, United States
I finally was able to make a "normal" trip. Tires broken in, weather mild, elevation changes minor and urban freeway speeds 60 to 70 mph on first leg and slower return, in heavy traffic at 45 to 65 mph. Here are the charts.
The trip B total miles are almost all higher speed (75 to 85 mph) and low temp miles. The trip A was today's 90 mile normal urban round trip. Mostly freeway but not high speeds.
Energy chart with rated miles line displayed. This segment was rush hour freeway with lower speeds (40 to 50 mph).
I drive pretty normal and dont worry much about trying to get better Wh/mi numbers. I just drive and don't use the brakes very much. No effort to maximize efficiency.
proven
296
194
Raleigh, NC
Thanks Roamer.. I've been wondering about that since most people have been posting 400+. I assumed it was mostly due to new tires, playing with the performance, etc and yours confirms that the X can get quite close to the S in Wh/mi.
vgrinshpun
5,886
22,789
PA
Thank you for the pictures, Roamer!
After scaling the "rated" line from the energy app, it appears that Model X rated energy consumption is 335 Wh/mile.
stickhrh
New Member
Jan 23, 2017
Louisville Kentucky
What Size tires on your model x
Saghost
8,217
7,007
Delaware
Mx75d : about 900 miles on the car in Connecticut (winter months) averaging 400-425wh/m ... much higher than my MS : which was about 320-330 with 34k miles lifetime.
Short trips in winter weather always give ugly results, as you're probably aware. Here's my five month old X75D:
And even that 335 Wh/mile number is driven up by far too many miles at 75 in freezing weather on my 4k+ of road trips since late October and a lot of winter commutes.
(I've recently started turning range mode on for the commute when it isn't precipitating - my ten miles aren't enough to get the battery warm anyway, so why waste power trying? The result is a 10-15% drop in energy usage, as you see here - 46 degrees, maybe a third of the drive at 75+.)
toxicpenguin
90
69
Greenwich,CT
I'm not too worried, and you are right ... almost all my trips are under 20mi. But it's not an apples to apples comparison with the MS which has seen 2 summers while MX is a newborn with only winter experience. I'm sure the average will drop once the weather warms up!
Cheers
Tjhappel
254
344
San Clemente, California
I have a 90d with 22's, took delivery in December and have about 4K miles on it. All freeway miles and very very conservative, I fond it almost impossible to get under ~375wh/mi. I really want to get the 20's just so I can get over 200 miles on a single charge. My 2014 p85 with 19's avg lifetime was 286 wh/mi. I was definitely expecting better than 380 avg with the x, I think it's wheel totally wheel related as most people with the 20's seems to be much closer to rated range than I am.
PGeer
168
79
Port Townsend, Wa
My 15,000 mile average is now 365 in a P90D with 20". It was 340 in October before we had our cold snap. As I recall, that's about what rated miles are (340-ish).
ohmman
Plaid-ish Moderator
Feb 13, 2014
9,971
18,017
North Bay, CA
I wish I could "pause" my lifetime trip meter when I am towing. Because a few hundred miles of 600Wh/mi towing kills my lifetime average, and I really enjoy trying to keep that number low.
Reactions: DrivingTheFuture
Khanhvngo
154
123
Maine
Hi, we took our x on a 3k round trip and the temputure was around 5-20 and I have calculated the average loss in energy was around 20-25% lost. We are still in the winter and after our road trip. All my route now I can predict what my end miles will be within 95% estimated.
We haven't had it in the summer time yet, so I don't know about the lost in that area.
In Maine I'm average 420 w/h
Reactions: Jurnimon
