Model X Falcon Doors
Discussion in 'Model X' started by Robert.Boston, Jan 9, 2012.
  1. MartinScorpio
    MartinScorpio Member
    Netherlands
    Both the Citroen C4 Picasso and the Opel Zafira have Parabolic Front Windscreens as options. So we have precedent ;-)
  2. Saghost
    Saghost Well-Known Member
    Delaware
    Noted. I'll still be shocked if this proposal turns out to be correct. :)
    Walter
  3. MartinScorpio
    Netherlands
    section-exterior-profile.jpg and as for the door, just move the handle. shape seems fine to me...
  4. drewgould
    drewgould Member
    North Canton, Ohio
    If you're so against the windshield and falcon wing doors, get a Model S. Seriously. Same rolling chassis, better battery pack size to range, the cargo areas are comparable in size (better in some ways on the Model S) and you can throw a luggage carrier on the roof for what doesn't fit.
  5. Saghost
    Delaware
    That wasn't the part I was talking about. I was thinking of the roof opening and changing the B pillar to work with the hinges and carry the large, heavy door. It's also longer than typical SUV rear doors, which presumably means it'll need more space to open safely.
    The handle is a non-issue - based on what we saw in the unveiling it sounded like none of the doors have actual handles, just touch sensitive plates that trigger the car to open the door. (Unless you plan to change that, too.)
    Walter
  6. CmdrThor
    CmdrThor Active Member
    Marietta, GA
  7. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    Parabolic != panoramic. The X has a panoramic windshield.
  8. AudubonB
    AudubonB One can NOT induce accuracy with precision!
    No, because if they were to do that it wouldn't be a Model X; it would be a Model ^.
  9. Electroman
    Electroman Supporting Member
    TX
    Why would Front Wheel Drive be optional?
  10. ohmman
    ohmman Plaid-ish Moderator
    North Bay, CA
    So that you can opt for tank-tread. Great for those snowy climbs.
  11. Electroman
    TX
    Now it makes sense.
  12. MrBoylan
    MrBoylan Member
    New York, NY
    I would be really surprised. The Falcon Wing Doors *define* the Model X. Musk has been selling the benefits of these over traditional doors and minivan doors since 2012 and has reiterated this as a core feature of the X. A Model X without Falcon Wing Doors would not be a Model X.
    It will be interesting to see how they deploy FWD on the next gen cars though. With the Model Y (model 3 SUV variant), since it will be unlikely to have a third row of seats, they could probably do *just* the Falcon Wing Doors with no traditional front doors. Since they've worked out most of the mechanical/design challenges of the FWD on the Model X, it should be easier to do a FWD on the next generation smaller SUV, and it could potentially replace two doors on a smaller car.
    -CB
  13. Discoducky
    Discoducky Happy owner of a P100D X and a brand new 2021 M3!
    Seattle
    I swear I had no prior knowledge of the auto-presenting front doors and I don't even remember making this post 3.75 years ago; my goodness, has it been that long???
  14. AnOutsider
    AnOutsider S532 # XS27
    Better questions is how you feel about the front doors now that they are auto opening
  15. SCModelX
    SCModelX Member
    Santa Cruz, CA
    Spot on
    Well, you hit that nail on the head, right !!?!?!
  16. Discoducky
    Seattle
    This feature will be particularly mind blowing to folks in showrooms and anyone I show the car too.
    I think it is a great idea, obviously, in that if I don't have to worry about the door hitting anything and it allows me to get in comfortably (i.e. the door is just as or more functional than if it was manually controlled) then this is a huge benefit.
    Several benefits of this feature are:
    1. Ease of use
    2. No damage to car from scratching paint from objects held in your hand or objects, like rings, on your fingers
    3. No hand burns from hot door handles or worries about frozen mechanical door handles
    4. No finger prints or hand oils on paint door handles
    5. Maybe even less air drag due to handle being perfectly flush...I'm pretty sure that is minor though
    6. No way to be car jacked...assuming someone pressing the handle from the outside can't get door to open
    7. Other autonomous scenarios...totally guessing here
    8. One less thing to fail...I just wonder about how to manually open the door if the chauffeur feature fails? But assume their is a manual way to open the door as well as a mechanism that could defeat ice build up.
  17. ohmman
    North Bay, CA
    Don't forget that holographic chauffeur retrofit!
