Model X FAQ (wiki)
Discussion in 'Model X' started by Wiki, Dec 27, 2015.
Tags:
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. Cookie Monster
    Sunnyvale, CA
    Thanks, no I don't seem to be able to edit the wiki (not enough posts?), feel free to update the wiki with my post with edits!
  2. pvogel
    pvogel Member
    Santa Clara, CA
    Added various corrections/additions. Mentioned USB port in third row, 6 seat config longest object question, AM radio clarification, brake light answer. Possibly a few other edits I'm forgetting.
  3. tstafford
    tstafford Active Member
    Nashville, TN
    Did anyone ever figure out the measurement from the ground to the seat height for the driver's seat? I'm particularly interested in this as compared to the MS. Wife finds the MS hard to get in and out of because it's too low. We want to order an MX but not until we know if she will be comfortable getting in and out.
  4. ohmman
    ohmman Plaid-ish Moderator
    North Bay, CA
    My MX suspension is set to High at our house. The seat is 29" from the ground. This compares to our MS (suspension set at Extra High) seat being 22" from the ground. Hope that's helpful.
  5. pvogel
    pvogel Member
    Santa Clara, CA
    Remember also that the seat has a good several inches of height adjustment in it, so a lot of those measurements will depend on your personal driving preference.
  6. tstafford
    Nashville, TN
    Thank you!
  7. HappyEV
    HappyEV Member
    Montreal, Canada
    What's the height clearance required to open the FWD at half-mast?
  8. SeanA
    SeanA Member
    Atlanta, GA
    Sorry for the delay. Every time I remembered to measure, I wasn't at home...
    Anyhow, It is hard to get a good measurement at the apex of the door at half mast, as it is on top of the car. I measured about 17" above the roofline.
    Not sure if that helps. Happy to try different measures or pics if desired. I thought I would have trouble with the doors in my garage and I haven't had a single issue. Opens up underneath the opener on one side and the rails on the other, dutifully avoiding the recycle bins ;)
    Sean
  9. Hengist
    Hengist Member
    Sacramento
    Updated and corrected dead 12 v battery instructions, added link for best practices when removing J1772 charger adapter.
  10. RxShah
    RxShah Member
    Bethesda, MD
    What's the HP on 75d?
  11. Hengist
    Hengist Member
    Sacramento
    The 60 D and 75 D have same power: 2 259 hp motors, battery will supply 328 hp.
  12. Lou gagna
    Lou gagna Member
    Princeton, NJ
    If I already set the cruise control (say 65 MPH), then brake. The cruise control becomes inactive.
    If, now, while it has already been set and inactive, I want to set it to another speed (say 45MPH) because I'm in a different situation, How can I do that?
    Every time I pull the lever to me, the cruise control goes back to 65MPH (in the given scenario).
  13. tliving
    tliving Member
    New England, USA
    Don't pull towards you, just push the lever down (I don't have AP, but that's how it works on my S)
  14. Lou gagna
    Lou gagna Member
    Princeton, NJ
    Thank you so much.
  15. Solarman004
    Solarman004 Member
    Colorado
    Pulling the lever toward you takes the car back to the previous set speed before you disengaged.
    To set a new speed, don't pull, just lift up on the stalk as if it were a turn signal.
  16. ScottieLV
    ScottieLV Member
    I have a question. I am hoping someone with Model X tow package and with their suspension set to towing height, what is the Hitch Height (when parked on level ground) from the ground to the top of the receiver opening? This dimension will help me buy the proper ball mount for my trailer. Thank you.
  17. vandacca
    vandacca ReActive Member
    Hamilton
    Not sure what towing height is, probably Standard or possibly "low" when driving. When I turn on Trailer Mode, it doesn't seem to affect the suspension, at least initially. Maybe when driving it will alter suspension, but it does nothing while parked.
    Anyway, I've provided all 5 suspension heights:
    Very Low=32cm (12 1/2")
    Low=34cm (13 1/2")
    Standard=36.2cm (14 1/4")
    High=37.7cm (14 3/4")
    Very High=39.5cm (15 1/2")
    Very Low:
    Low:
    Standard:
    High:
    Very High:
    • Informative x 3
  18. vandacca
    Hamilton
    No good deed goes unpunished. After playing around with the suspension, it sounded like my compressor was running for a bit (re-pressurizing?). When I came back to my vehicle, I heard a loud pop by the front-passenger wheel and now my suspension is stuck in "Very Low". I also have a "Air Suspension Needs Service: Contact Tesla Service" warning on the IC. :(
  19. Gwgan
    Gwgan Almost a wagon
    Maine
    :( is right. Hope it is an easy fix.
  20. vandacca
    Hamilton
    I immediately tried to bounce the console and IC and it didn't help. Took pictures and called Tesla Roadside assistance. They said it all looked fine from their end, so they had me go back to the vehicle and the warning disappeared and now I'm able to change suspension settings again.
    Hopefully, it was just a quirk, but just in case they are pulling my logs and reviewing them at the time of the problem. Hopefully, I'll know tomorrow how serious it was/is.
Thread Status:
