pvogel
The next thing was really strange. I was trying out the autopilot. I had used it alway to my designation. I was thinking how amazing it was as it drove very similar to the way I drive. On the way back I was on a four lane street (two lanes in each directions). It had a 45 mph limit. I was in the left lane and there was a car about 4-5 lengths in front of me. I had been on this road for about 5 minutes There was a car in my right lane which was slowing to make a right turn. All of a sudden my car pulled to the right like it was following the car which was going to turn right and if I hadn't aggressive steered back in my lane I am sure I would have hit the car. The pavement lines were normal and I did not see anything abnormal. I went from probably being over confident with the autopilot/auto-steering to a making sure I am paying complete attention
Yeah, the Autopilot works flawlessly on a highway, on surface streets it's a little less reliable, watch things on your dashboard display that are highlighted in blue, that's what the car is cuing off of to steer. If the car in front of you was blue, and then somehow the blue popped over to the car making the right turn you would get something like that. I had a similar case a little while ago giving someone from work a test ride and running in autopilot behind a bus. The bus slowed to pull over to the side for a stop, but wasn't *quite* out of my lane, the autopilot decided it was out of my lane and it was going to go past, even though there wasn't room to do so safely in my lane.
I live on the south end of Merritt Island. The north end of the Island is the Merritt Island National Wildlife Refuge along with the Kenndedy Space Center. MThe south ten miles of the island is all residential and varies in width with most of it being one to two lots deep with the lots being 500-1000 deep each. There is only one road (SR-3) running north to south through the majority of the island and it is only one lane in each direction with no shoulder. The speed limit on this road constantly varies between 30-45 mph. The first 2 miles after coming onto the island across the south end bridge and driving north on SR-3 is 30 mph. The county police frequently give tickets on this part of the road. Knowing they are real strick on speeding on the island I have my car set to no more than 3 miles above the limit. Today I came across the south bridge and started north on SR-3. The car is going about 33 mph and before we get 1000 feet the car speeds up to over 40 mph in a 30 mph zone. I know the car uses GPS coordinates and the front camera reads the speed limit signs. I know the way it is now if I were to continue to use autopilot on this road it wouldn't be long before I have a ticket. Does anyone know if there is a way of setting the speed for a section of road to a specific mph.
Easiest thing would be to steal a 30 mph speed limit sign and prop it up on the side of the road, then drive the MX past it That will update the system with the new speed limit for that section of the road Or, go the OTHER direction (south) on SR-3 until you know you've passed at least one official speed limit sign, now turn around and head back NORTH on SR-3, the MX will see the 30mph speed limit and update it's database, keep driving north until the next speed limit sign appears, now the car knows from limit sign 1 to limit sign 2 the speed limit is as indicated on limit sign 1.
