I’ve searched for other experiences and don’t think I’ve found the same situation. Seems a lot of people have experienced squealing and noise on closing and opening the windows as a result of the seals needing lubrications or other calibration or adjustment but what I am experiencing is different and consistent from left to right front windows.
At the last moment of full close pressure closing the window with the switch or when the door closes and the window extends in to the frame, there is a popping or clunking noise coming from the door/window when the last bit of full pressure is applied. Almost like a cracking knuckle. The same happens as soon as the pressure is released when the window lowers either using the switch or commanding the door open.
Anything I’ve come across regarding the front windows seems to require lubricating the seals and resetting and recalibrating the regulator, both of which I’ve done and the noise is still there. It’s consistent left to right which makes me think it might be “normal”, but wondering if others are experiencing anything similar. I feel like if it was a lose joint in the linkage or something, it likely would only be one of the windows. The windows seal great and retract/extend on door opening and closing perfect, just worried that it’s prematurely wearing something in there out. Thoughts?!
