Model X has single 72A charger
Cosmacelf
8,264
19,529
San Diego
I suspect a software engineer coded the limitation in without a good understanding of the true engineering limits. Similar to how the original Model S would limit itself to 20A charging from 120V sources. That limit made no sense, and neither does this one.
dhanson865
4,345
5,734
Knoxville, Tennessee
Not really... the ~500W difference between 70A and 72A at 250V isn't really meaningful. Wires are sized to carry 72A, regardless of voltage, and a 10V difference is unlikely to make a difference in isolation concerns. Considering the ANSI standard for power is +/- 12V (228V-252V), it wouldn't seem right to design it with that tight of a tolerance.
I'm going to send this in to see if I can get an answer.
Seems reasonable to me.
My Leaf has a 16a charger and I often see over 240v in my garage. So the charger starts pulling at x.5a and then floats around up to x.7a sometimes depending on the voltage. I see the same even if i limit x to 14 or 12 or 10. It doesn't care about the max limit it seems to try to honor the pilot signal request or float around the starting KW as the voltage varies. I'm not sure the logic but it sure isn't power limited (on a 50a circuit, 14-50 socket, 30a evse, 16a on board charger and it'll still floats around between 11.5a and 11.7a when my voltage varies from 241 to 246). Leafspy shows 2.5 or 2.6KW on a 12a setting for the EVSE (some rounding or truncation there).
I'd be fine with it pulling 12a no matter what and the KW fluctuating instead but it doesn't.
so if 72a x 240v = 17,280 watts aka 17.28 KW I wouldn't be surprised if the charger floats around 17.3 KW or less even if the hardware could handle more.
pvogel
917
199
Santa Clara, CA
Depends on your state of charge on the batteries. Lithium battery charging involves two phases: Constant Current (deliver a steady current to the batteries) and Constant Voltage. During the Constant voltage phase the voltage from individual cells is checked and cells whose voltage is at the desired voltage have alias applied to them while cells below the desired voltage do not (this is called balancing and is absolutely critical to the life and safety of the pack) the amps are slowly ramped down during the CV phase until there is at most a 1-2mV (usually 0 mV) difference in the tested voltage of each cell in the pack.
The charger is designed for whatever maximum current it is designed for and/or set for by the installer based on the load calculation for the available supply. It won't go above that load no matter what you ask for or how fluctuations in the supply voltage would or would not allow based on watts. When considering what's acceptable AC use in any install, AMPs, not watts, are the figure of relevance.
Mar 5, 2016
12
67
France, South
Go to the design studio in your browser. Once your options show up, simply type 'charger' on your keyboard (you aren't typing into any text field or anything) the option will be added to the page at the bottom
Apparently, it does not work in Europe (or in France at least). When I type "charger" or "chargeur" in french, nothing change. Do you know if the charger is different from country to country?
satheesh.net
President | Tesla Owners Club Norway
Aug 10, 2013
159
46
Norway
All Model X' delivered to Europe has 16,5kW charger. Nothing more, nothing less. And you can only get this option, there is no other option to choose from - unfortunately.
Cyclone
Cyclonic Member ((.oO))
Jan 12, 2015
5,056
1,141
Charlotte, NC
Weren't all Signatures in the US offered with 72A only as well? Then all production models offered with the smaller charger as standard?
If I recall correctly, in the US, Founders got 72 amp by default, Sig got 48 amp by default with 72 amp a free upgrade if you request it. Production is a paid upgrade for 72 amp.
dhanson865
4,345
5,734
If I recall correctly, in the US, Founders got 72 amp by default, Sig got 40 amp by default with 72 amp a free upgrade if you request it. Production is a paid upgrade for 72 amp.
Model X is 48a or 72a. No 40a chargers in Model X anywhere. 48a is 20% more power, but more than 20% faster charging if you are on a HPWC that can do the KW.
If you wonder how can 20% more power exceed 20% faster charging, that comes down to net vs gross. It's 20% more gross, the overhead/vampire drain is fixed, so the additional energy goes straight to the battery (minus charging inefficiencies) and the Net increase is more than 20%.
Mark Z
1,842
1,300
North Orange County
The early Model X Signature vehicles came with the 72 amp charger by default. I never read that any Signature had a 48 amp charger. We paid for a fully optioned vehicle, so it wouldn't make sense to ship 48 amp chargers for any Signature buyer.
Not sure what the "Design Studio" options would show today for the remaining Signatures that have yet to configure.
Paul Carter
1,735
510
Canada
On the Wall Connector instructions for electricians the table says it’s possible to charge Model X at 45 miles/hour with a 100amp circuit and 40mph with an 80amp. If the onboard charger is 72amp why is there a difference?
https://www.teslamotors.com/sites/default/files/downloads/charging_wall_connector.pdf
Its the source circuit amp. 80% of 80 amp = 64 amps < 72 amps (the max that the X upgraded charger can take). The 100 amp can deliver 79-80 amps to a dual charger Model S, a little more than the Model X upgraded charger can handle, but will only take max 72 from it. Hope that helps!
Reactions: Gwgan
aegis395
New Member
Aug 17, 2015
2
2
Kirkland, WA
Circuits are derated at 80% with continuous loads so a 100 amp circuit will supply 80 amps (slightly exceeding the 72 amp onboard charger) while the 80 amp circuit will supply 64 amps (slightly below the 72 amp onboard charger).
64 / 72 = 0.88
0.88 * 45 mph = 39.6 (or ~40 mph)
Reactions: Gwgan
