If you bought this car thinking you’re going to leave Sentry on 24/7, including at home, without the car being plugged in, you are going to be very disappointed. As you’ve quickly discovered, it’s a massive waste of energy. Refresh S/X are even worse, powering that fancy AMD Ryzen MCU…
Here is what Sentry power draw looks like on my car, when I was using it and could actually measure it (using Chargepoint in airport parking garage). The EVSE is using shared power, so the output fluctuates, but we can see 3 different charging schemes:
1. First 11 hours: Arrived with an almost empty battery (around 6-8% SoC) and charged to the 60% set point
2. Between 11 hours and 51 hours: Maintaining charge level at 60% set point; Sentry Mode was on and as the vehicle's battery went below 60%, the car activated the OBC to charge it back up to that level
3. 51 hours to 63 hours: Bumped charge level up to 100% the morning before boarding my return flight; vehicle reached 100% at 63 hours, about 5 minutes before I got back to the garage and drove off (I calculated when I expected it to hit 100% and tried to get it close but didn't expect it would be timed that well...lol)
Now you can't actually see it on this image, but by clicking on certain regions of the photo, I can get the time and total accumulated energy up until that point. At 11 hours, when the power level first fell to zero, the accumulated energy was 46.17 kWh. At 51 hours, just before I bumped the charge level up, the accumulated energy was 54.21 kWh. From this, we can see that the vehicle used 8.04 kWh to maintain the battery charge level at 60% in 40 hours (may be a slight underestimate; battery fluctuates between 57% and 61% in a sort of hysteresis cycle). This was an average power draw of .201 kWh/hour or 201W. On the Model 3, it is roughly the equivalent of driving 18-20 miles a day. Cost of doing this? Well, at the airport, charging was free, but over the long run, 4.824 kWh multiplied by whatever you're paying per kWh, per day. If you do it 24/7/365, that's like putting 7000 "miles" on your battery (over 1700 kWh per year) just for standing still. And if you assume you pay 25¢/kWh off-peak, about average for California, that's $440.19 a year. It's also a lot of extra wear and tear on the battery and expense to run Sentry Mode all of the time, plus it prevents the car from properly calibrating its gauge. I'll use it when I'm parked at shopping centers and on the side of the street running errands but never at work or at home.
