Model X Liftgate
Gentilly7
188
57
US
Does the Model X come with a power/automatic liftgate without Premium Upgrades package? Service advisor says it does not but I do not see it listed in the PUP description either. Standard equipment lists automatic liftgate. Thanks in advance.
Pandamoanium
655
254
Colorado
On mine it is. I think it is standard, but you should really make sure and have it in writing. I mean, Tesla changes things without telling people all the time. While small, it would be good to know.
ab26
353
187
Bay Area, CA
I don't have PUP and mine has automatic lift gate (which is you can close and open it with a press of a button using the remote or touchscreen).
Jrogville
660
253
High Springs, Florida
If you look at the order sheet of the S, it lists the power lift gate as an option. Perhaps your hesitation is because they call it automatic rather than power on the X. But there are other things that are standard on the X that are options on the S, like air suspension and all wheel drive. Also, the manual makes no reference to power being an option. The liftgate is only discussed in terms of it being powered.
karupspc
37
18
San Jose, CA
My owner advisor when inquired about it said on the Model X the automatic lift gate only opens from the vehicle a bit then you'll have to push it up rest of way. And there's no push button to close it either. It is not fully automatic (i.e. opens all the way) on the key fob. Only means to get this function is the Premium upgrade.
I'm super confused now.
Fiddler
105
115
Bowie, Md
ab26 said "I don't have PUP and mine has automatic lift gate (which is you can close and open it with a press of a button using the remote or touchscreen)."
Same here, works great; however, it might be true the lift gate only opens half way automatically. I assumed the half way was because of overhead storage, but even half way is good enough for me to use the trunk without issues. PUP not needed.
Saghost
8,216
7,000
Delaware
It sounds like someone confused the S and X to me - either your OA or whoever they asked. To the best of my knowledge, every X has a power liftgate and power for all four doors.
Reactions: beths11 and RIZE
travwill
1,335
480
Chicago, IL
It is standard. Works with fob to open and close. Opens and closes from touchscreen also. Finally, it has a sensor or uses the one in roof the the X to avoid raising into something, but that causes some issues with opening it all the way at times on X - as the memory set doesn't really override it.
Solarman004
743
976
Colorado
As others said, even without the PUP, the liftgate is automatic and can be controlled from the pushbutton on the liftgate and the 17" screen.
You can also program how high it opens.
Not only that, I confirmed in my non-PUP 75D, that the new FOB triple-click "Close All" will indeed close the liftgate.
LovelyCarrot
43
44
Seattle
Does everyone else's liftgate just craaaaawwll upward? Seriously it seems like it's just groaning and straining to get that back end up. SC looked at it and tweaked a little but it still is slow as crap.
