Model X Option Speculation
Discussion in 'Model X' started by ilovtesl, Apr 3, 2014.
Tags:
  1. ilovtesl
    ilovtesl Member
    Atlanta
    Do you think tesla will announce the 110kw battery for model x which will give it 325 miles???
  2. Raffy.Roma
    Raffy.Roma Active Member
    Rome (Italy)
  3. MikeL
    MikeL some guy
    No :tongue:
  4. ilovtesl
    ilovtesl Member
    Atlanta
    why yes and no???
  5. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    Possibly.
    - - - Updated - - -
    Why do you think anyone would actually know?
  6. MikeL
    MikeL some guy
    So you now have the entire range of possible answers. :smile:
    Reasons for "no" are Weight, $$$$$, and the fact that it's on the Model S platform which, for now is 60 & 85 kWh - only.
    But . . . the only constant is change. You know that new battery developments are coming, so . . .
  7. Shumdit
    Shumdit Member
    SC
    Yes, 110 or other larger battery than the current 85, but no it will not get 325 miles or rated range. It also might not be available at launch. I am thinking they need to get the battery cost down unless the model X is going to start at six figures.
  8. engle
    engle In 1976 Looking ahead to 2030!
    Above Tesla's Fremont Factory until Jan 1: Taipei!
    My guess is yes for the "Performance" Model X as an option, since they have a higher margin on the battery upgrades, correct? I believe that's why they quote a shorter delivery time for the Model S Performance, yes? Whenever it does happen I think they will announce the option for the Model S, also, at the same time, since the basic platform is shared. What is the estimated EPA range of a Model S with a 110kw battery?
    Patiently waiting... (Actually, to be honest, I refresh the "Model X" main page here on more than a daily basis!!!)
  9. Nubo
    Nubo Test Mule
    SF Bay Area
    Yes because a larger battery will probably be necessary to maintain range parity with Model S. I think the market would react poorly to any significant range reduction. Tesla has instilled an expectation that EVs, and especially Tesla EVs, will improve over time. And Model S will be over 2 years old. There's no room to be taking a step back, imho.
  10. ilovtesl
    ilovtesl Member
    Atlanta
    still i think they will do it or at least for signature model x owners
  11. Kevin Harney
    Kevin Harney Active Member
    Herndon, VA
    It would be silly to spend all that R and D for only the Signatures. More likely all Performance models.
  12. gjunky
    gjunky Trifecta: Solar and both cars are EVs
    Scottsdale, AZ
  13. GenericSpoon
    GenericSpoon Member
    Canada
    I don't think they will add a larger battery than 85kWh for cost reasons, parts commonality between the Model S and Model X(for the battery pack/drivetrain) and the fact that it is expected by pretty much everyone that the Model X's range will be lower than that of a comparable Model S in addition to its range that will surely be enough to cover the distance between two SuperChargers.
  14. darthvdr
    darthvdr Member
    los gatos, ca
    Tesla has a tendency to overdeliver, so fingers crossed for my son that there is a larger battery option
  15. ilovtesl
    ilovtesl Member
    Atlanta
    I really really hope they add a battery like a 110 to make up for the miles that it lost because of it's size
  16. qwk
    qwk P130DL
    You must be new to Tesla. The sig owners get less choice not more.
  17. uscrxdr
    uscrxdr New Member
    Whittier,CA
    since the model x will have 2 motors, it can't get the same range as the s with the 85kw battery
  18. AnOutsider
    AnOutsider S532 # XS27
    I'm not so sure it has to do with the motors as much as the size of the beast. Even if it weighs about the same, there's just more to move through the air.
  19. sandwich
    sandwich Member
    Carolinas
    Earlier this year in Oslo, Elon said that the X would be 10% less efficient than the S primarily due to larger frontal area moving through the air. JB has stated that adding the second drive unit is energy neutral . There is no mechanical linkage between the front and rear units, so no efficiency loss there.
  20. aronth5
    aronth5 Long Time Follower
    Boston Suburb
    The Model S 60 kWh has an EPA rated range of 208. I believe Tesla will somehow make sure the X's 60 kWh range doesn't fall below 200 miles which seems to be Elon's sweet spot.
    Not ruling out a larger batter but there are other options. For example cameras instead of windows "might" do the trick.
