Model X Performance - is this wh/m normal
Rdt123
156
46
Billingham
Hi all
Had my MX Performance 2 weeks. So far over the 700 miles ive done ive averaged 456wh/m. This would only give me around 180 miles max.
I've tried putting it in range mode and setting the cruise control to 60 mph and ive still not seen as low as 300wh/m
Is this normal? the range isn't what i expected. To be fair with free supercharging and a 7kw home charger it doesn't really matter but as i say its not currently being anywhere near as efficient as i thought
It's on 22" turbines
Rob
Saghost
8,216
7,000
Delaware
Lifetime on my Ludicrous Raven is ~320 Wh/mile, and that's higher than it should be because of sticky winter tires this past winter.
But the 22" rims and the stickier tires that come with them are said to be 10-15% less efficient, and new drivers experimenting with what the car can do will likely take more power. :)
Trip length makes a big difference, too, with shorter trips taking more energy as the HVAC brings the cabin to a comfortable temperature. It's especially painful on short trips in the cold.
Reactions: Rocky_H
DCGOO
1,494
886
Indianapolis, IN
Hi all
Rob
Seems pretty normal to me, especially in the first 700 miles. The 22 inch wheels suck watts like crazy
Reactions: Fiver and Rocky_H
Cperry
22
4
Oakland
That’s what I didn’t realize when I bought my MX P100DL you get all the acceleration you want but not the mileage you’d expect. A 75D will have better range I think. That was puzzling. I guess the 22” wider wheels, spoke design and the design for speed in ludicrous mode make a huge difference.
DCGOO
1,494
886
Indianapolis, IN
Actually it is mainly the tires. High performance tires simply stick to the pavement much more aggressively than the low rolling resistance tires on the 20-inch wheels. More stick means less energy efficient. My X came with 20 inch wheels, I got a set of 22-inch wheels (promotional spiff a couple of years ago) and used them for about six months. Sold them.
RedXowner
176
96
Springfield, Virginia
My 2016 MX P100D came with 20" wheels as that was my requirement. My personal preference is to have the better performing tires for range and towing. 22" severely limits towing. Just now learning they significantly limit range too. But I don't seem to have any trouble whatsoever with my 0-60 performance with the 20" wheels/tires. IMO, 456 Wh/mi is way too high for going 60mph on a relatively flat highway and not driving highly aggressively. My average when not towing my boat is closer to 320 roaming around the hilly Virginia countryside, and I get on it every now and then. When I don't, I can stay just under 300.
mswlogo
5,965
4,572
MA, NH
I’m averaging 276 wh/m on 20” non Performance for the last 1200 miles. That’s with 50% AC and some towing.
P85_DA
4,171
2,872
2018 XP100 on 22s lifetime I’m at ~ 420wh/m averaging driving 70-75 current car has 70k miles I don’t think I ever made it to 200 miles on a 90% charge ;)
  • Disagree
Reactions: JulienW and sllvgl
skip8jj
261
110
Portland, OR
Oops, you got me there. So, mine is 400 Wh/mile then. Not so ludicrous anymore...
We have 26,600 miles on our MX at 309 Whrs/mile for average. On trips, we seldom exceed 70mph, usually cruising at 60-65. Trips have included runs over the Wasatch and Cedar Breaks in Utah. All with HDW 2+. Not sure if that will hold with recent install of HDW 3 and Version 2020.20.12 xxx. So far the software seems to be accelerating battery drain.
Reactions: sllvgl
Qbenjamin
Frugal But Classy!
Jan 7, 2017
1,139
673
Braavos
Yep, the X is extremely inefficient unfortunately. The 22's are a range killer as well. I avg around 415 Wh/mi in the summer. Let's not even discuss winter range with 20's, its absolutely maddening.
ModelNforNerd
4,078
3,890
Ayer, MA
