Sentence written, words placed in a particular order, more detailed words and terminology added towards end of sentence.
I admire your style! But, while words were placed in a particular order in what I wrote, what I wrote is not a sentence.
vandacca,
I will stay tuned. I know from experience that no good deed will go unpunished. As the presentence investigation is conducted, I hope that the following facts will be taken into consideration. I am a long-time MX reservation holder and I deserve credit for the punishment inflicted to date. (Tesla seems to adhere to Lewis CarrolI’s suggestion: first the punishment then the trial.) Also, I spend considerable time on this site dealing with these sorts of comments. While not unusual, it is at times cruel.
Your opening sentence makes no sense. 240 is the number from Tesla. No vehicles have been delievered. Your "in light of" and "factors" remarks are just obvious things talked about in every range discussion.vandacca,
It is encouraging, but the weird thing is that the Model S 90D apparently has the same EPA range as the Model S 85D (270 miles) which doesn't make much sense. Unless the EPA changed how they rate range between when they tested the Model S 85D and the 90D. Or the Model S 90D hasn't officially been tested yet... but the X has, which is also odd.We now have another TMC thread: “Official EPA range”
Official EPA range
That thread is consistent with other sources: See, e.g., “BREAKING: EPA Rates Tesla Model X Range – 90D 257 Miles, P90D 250 Miles”
BREAKING: EPA Rates Tesla Model X Range - 90D 257 Miles, P90D 250 Miles
The EPA range indicated for the MX is: 257 for the 90D and 250 for the P90D.
This compares with 270 for the MS 90D. The validity of the individual numbers and the MX-MS comparison remains to be seen. (I am skeptical. It seems to me that the MX does surprisingly well. The MX 90D only gets 13 miles less EPA range than the MS 90D.)
All I am saying is that the difference between S and X is 30 miles and not 13 miles for a 90D.
And that 30 miles difference seems in line with expectations.
So if you can squeeze 250 miles on a full charge driving an S90D for a typical drive, you can expect to get no more than 220 from an X90D for the same drive and conditions.
I know this thread has been cold for a while now but I think its time to resurrect it! The quote above accurately reflected my initial impression based on Tesla published information but seems to be less accurate based in comments from actual Model X owners. I have been having this discussion with Model X owners on the Model X Owners Group on Facebook:
"Model X Road Trip - I am waiting on my MX P90D VIN 000229 to arrive but I am trying to plan a road trip to visit family after it comes in. I know the "rated" range is 250 miles but have any of you MX owners taken an extended trip and determined the actual highway/interstate range per charge? My closest family is 700 miles away so it will definitely be a Supercharger tour. Thanks in advance for any feedback and congrats on your awesome new vehicles!"
The data I am looking for is the following:
1. Rated range vs. what you are actually getting since most Model X owners I have contacted are averaging around 500Wh/mile in the P90D variant which won't get you 250 miles per charge
2. Accuracy of the onboard trip planner in the Model X - I know how accurate it is for the Model S so lets get feedback for the Model X
3. If you are using EVTripPlanner.com, which Model S variant and/or factors seem to be closest to your Model X
Thanks, in advance for any feedback actual Model X owners can provide!
I always depart with a full range charge then try to stay on the bottom of the battery as much as possible at each enroute stop. It is wasted time to charge beyond a safe margin to make the next stop. If the wheels are not turning the car should be charging.
i posted some initial numbers here;
Random Model X sightings - Page 112
I use a P85D on 21's as my EVtripplanner baseline. That seems to track very well with the P90D L on 20's. My first five hundred miles spooked me then the number started improving. The screen shots I posted include lots of below 30 degree driving. At one point the outside temp was so low I ran both heaters on HI for a while. At 12 degrees and 75 mph it stayed warm but required running the systems at higher than normal temp settings.
I also just just realized that my numbers include at least twenty test drives involving several Ludicrous power runs each. So the data I posted is pretty worst case.
- - - Updated - - -
The onboard trip planner improves with use. It learns how you drive and after a few legs it is very accurate. I use the trip graph on every travel leg and I also use the trip graph when charging. I recommend charging to a 20% buffer on the first few travel legs then dropping to 10% as it improves accuracy. I always depart with a full range charge then try to stay on the bottom of the battery as much as possible at each enroute stop. It is wasted time to charge beyond a safe margin to make the next stop. If the wheels are not turning the car should be charging.
