Model X rear seat floor removal
MCGotX
6
0
Fremont
Some coins slipped under the mono post seats and now the seat cannot move all the way back. There is some noise when moving the seat back and forth. Need to remove the floor panels and retrieve those coins slipped in from the gap. Has anyone removed the floor panels? They seem to be removal but the entry sill plate is preventing from total removal. Any suggestions on removing the X sill plate without damage? Thanks!
Slylynn
New Member
Oct 9, 2019
American Fork
While looking to answer the same question, I can across this in the manual.
"Stamped on the chassis under the sill panel on the rear passenger door. To remove the sill panel, gently pry it upward using a flat-bladed tool.Caution: Removing the sill panel to view the VIN is not recommended because damage is likely to occur. The panel is held in place with fragile clips that break easily. Damage caused by removing the sill panel is not covered by the warranty."
I have not tried to remove the panel myself.
