Model x roof racked
Discussion in 'Model X: Interior & Exterior' started by Qkedarg, Sep 24, 2016.
  1. Qkedarg
    Qkedarg New Member
    So I'm taking at least one rowing single on my model x. I plan on using seasucker paddle board roof racks. I could either put them all on the glass, or I can use a hitch mount cross bar the same height as my front sea sucker. Not sure which I will do there yet. Basically it looks like at least one of the two ways will work fine.
    My main question is what happens if the wing doors are opened via an accidental push on the keyfob. Is there a way to disable the falcon doors either in the interface or by removing a select fuse. It would be nice to be able to use the windows as this is likely to be the main passenger entry method while enroute.
