Model X Standard Battery Size
Discussion in 'Model X' started by Ron M., Jul 11, 2019.
  1. Ron M.
    Ron M. New Member
    Sparks, NV
    I just bought a new Raven Model X Standard (not the long range). I have read elsewhere that all Ravens have the 100 KW battery, including mine. The range limit is a software limit, not a battery limit. Does anyone know if this is true? Just curious. Thanks!
  2. Tam
    Tam Well-Known Member
    Visalia, CA
    You can check it out your self by reading the battery label if you turn your front wheels all the way to the left then lay down next the right front wheel and look up toward the center toward the front:
    • Helpful x 2
  3. Ron M.
    Ron M. New Member
    Sparks, NV
    Thanks, I found it. It shows 75 kWh. So much for the rumor.
    • Informative x 2
