acarney
600wh/mi is fantastic! That means a Model Y would likely still be able to do about 100 miles between chargers without much panic. I still firmly believe that we need 150kWh to 175kWh. At 150kWh you could do 70% charge (so supercharge to 80% and drive down to 10%) and get about 175 miles between charges. That's pretty good, but still would only give you about 70 to 80 miles away from a charger into the wilderness and back out to the charger. At 175kWh you could do about 200 miles between charging stops and about 100 miles out away from a charger. I think that's probably ideal. That should cover most areas (certainly good around the Pacific Northwest) and even fairly remote places.
Sadly it doesn't look like we're going to see much capacity increase until battery supply really gets sorted out. I know Musk loves to brag about how no one needs a larger battery, but really it's that *HE* doesn't need to sell a larger battery right now. Give it a few more years and when we see trucks starting to get 150+ kWh and being able to tow you'll start to see the X get some serious towing ability and whenever CyberTruck comes out. I suspect S will trickle up slowly too, but probably only to 125kWh or so just to keep that longest range number and greatly help those in cold areas actually do like 300 miles on a charge.
