Model X weld/seam cracking
Discussion in 'Model X: Interior & Exterior' started by Matutino, Oct 26, 2017.
  1. Matutino
    Matutino Member
    Lake Forest, CA
    Is this normal, I noticed this on each side right where the falcon doors latch, as you can see the seam is cracked
  2. dark
    dark Member
    california
  3. Matutino
    Matutino Member
    Lake Forest, CA
    Can anyone with an x snap a pic and post it.
    I’m taking mine to service next week due to thisz
  4. beachbum77
    beachbum77 Banned
    Hot & humid Florida
    That is one of the worst weld jobs I have ever seen. Where is QA at Tesla? This should have never made it out of the weld station. This is what you get when machines build machines without any humans checking the work.
  5. bwho9000
    bwho9000 Member
    Sugar Land, Texas
    On mine, there is a weld, but it isn’t cracked. Is that okay?
  6. Lbkmxp100d
    Lbkmxp100d Member
    Lubbock, TX
    #6 Lbkmxp100d, Oct 27, 2017
    BC607913-9613-4FF6-918B-AAFA5E0C7195.jpeg C8B58A78-57C0-40B6-8ACC-3A3EF90DE77E.jpeg BC607913-9613-4FF6-918B-AAFA5E0C7195.jpeg I just took a look at both our MX’s. The white X is a December ‘16 build and black is June ‘17 build. As you can see, my white December ‘16 build is cracked as well and the June ‘17 build is perfect. Is your X a performance model? Reason I ask is, my white X is a P100DL while the black is a 100D and I’m wondering if the additional stress with performance models could cause the crack. Although, the weld itself looks much better with our newer black X.
  7. Jays200
    Jays200 Member
    Perth, Western Australia
    Both sides of mine are the same VIN 42xxx
    Not that happy about it but it's more cosmetic than structural. It's like the seam filler has pulled away from one side. I've had it recorded with Tesla.
    I'm sure you're familiar with the saying, "My bum's got a crack in it but it still works". ;)
  8. Plan B
    Plan B Active Member
    EARTH
  9. Matutino
    Matutino Member
    Lake Forest, CA
    It is filler sealant and not weld as I originally thought.
    Mine is a July 17 75D so is not related to power/performance.
    I’m taking mine next week for other items and definitely pointing this out for them and get it recorded at Tesla.
  10. Evoforce
    Evoforce Active Member
    Fountain Hills AZ
    Yes, I was going to say, that is not structural, that is seam filler. It helps against corrosion and provides some aesthetic value.
  11. oneplusinc
    oneplusinc Member
    Maryland
  12. oneplusinc
    oneplusinc Member
    Maryland
    Going in tomorrow for service. Will report back.
  13. Oppajer
    Oppajer Member
    Point Richmond, CA
    Showed my 2018 July 75D weld crack to the service advisor and they said they can send it to the body shop to smooth out and fill in/repaint. Should take about a week.
  14. Evoforce
    Fountain Hills AZ
    By the way, as earlier reported, that is not a weld crack. It is also not a structural failure. It is a glue/sealant
    filled connection and is sealing against corrosion/dirt and also makes the joint look better.
  15. oneplusinc
    oneplusinc Member
    Maryland
    Why would Tesla put body paint over a flexible sealant? I don't recon I've ever seen this on a car - yes on baseboard and sheet rock junction, but not a car. ;) Seems the proper design would have been a gasket.
    Prior poster said it took a week to repair at body shop. Mine went in yesterday and they said it would be ready today. I'm curious what they're doing to fix mine. Will report back.
  16. Evoforce
    Fountain Hills AZ
    #16 Evoforce, Aug 2, 2018
    That is standard industry practice to use sealants and epoxy and many are made to be painted over. Many brands have done that in the past and will do in the future. It fills in a body seam and has a little flexibility. Sometimes the paint isn't quite as flexible or the body flexes enough that it can also crack the sealant/epoxy. Bottom line, not a weld crack, aesthetic only! Nothing to worry about. An additive can be added to the paint but it is not usually done for one small seam like that. It is possible that they will use a little more flexible sealant/epoxy in that spot in the future but it is such a minor thing that they may not.
  17. Oppajer
    Oppajer Member
    Point Richmond, CA
    I don't get why people say it's flexible. When I touch it it seems like it's part of the metal. It was bent like metal and does not feel like rubber at all.
  18. Evoforce
    Fountain Hills AZ
    #18 Evoforce, Aug 4, 2018
    Some are more flexible than others. A large variety of different seam fillers/body epoxies are used depending on what its needed application calls for. They may wish they would have used a slightly more flexible one in this location. It would have stopped the panic of some who think it is a mechanical weld failing. There is much more glue/adhesives/epoxies being used in modern manufacturing than ever before.
  19. jboy210
    jboy210 Supporting Member
    Northern California
    If any one else is curious about this seam sealer, watch this video showing how they use it and other compounds in modern car construction and repair.
    • Informative x 2
  20. A.N. Gineer
    A.N. Gineer Member
    Pacific Northwet
    Does anyone have a source for the orange seam sealer?
