Model X wheels tires and ride height
Discussion in 'Model X' started by Kipernicus, Feb 10, 2012.
Tags:
  1. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    It appears that the X does have better ground clearance, but it's no range rover.
    1. It appears they had the S turbine wheels on, but I can't tell if it's the same 21" size
    2. Perhaps if they put taller rubber on the same wheels it would increase ride height a bit - did anyone notice the tire size?
    3. I read somewhere that the adjustable suspension can add an inch of height, which doesn't seem like a lot
    Those of you who expressed a need for better clearance - do you think the X provides enough?
  2. vfx
    vfx Well-Known Member
    CA CA
    One article said it has 1" of ride height adjustment.
  3. Lyon
    Lyon 2016 S P100DL, 2016 X P90D
    Eugene, Oregon
    I'm really hoping that it will be able to do DOWN quite a bit. I imagine that a few inches might make the difference between hitting the ceiling of a parking garage and having enough clearance.
  4. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I'm sure that they can place the equivalent of a parking sensor on the doors to stop the opening process should there be something in the way of opening to it's fullest extent.
  5. Lyon
    Eugene, Oregon
    That sounds like a plan. Listen up, Tesla, we want auto-stop falcon doors.
  6. NigelM
    NigelM Recovering Member
    Northern Virginia
    Regarding ride height: Over here I posted the below pic, assuming that Tesla's website pic is to scale and we know the Model S ground clearance is 6.1" then the Model X ground clearance must be 7.9"
