Model X60D vs ModelX75D Performance
Discussion in 'Model X' started by MXWing, May 11, 2017.
Tags:
  1. MXWing
    MXWing Well-Known Member
    I recall there being a performance increase between the 60D and 75D but can't look it up anymore with the 60D being offline on Tesla's site.
    Anyone recall what that was and if you get that boost from the capacity upgrade?
    Thanks
  2. outie
    outie Active Member
    SoCal
    You do not get any performance boost going from 60 to 75. The performance is only increased @ 90D/100D.
  3. nikeykid
    nikeykid Member
    Fremont, CA
    agreed, same performance. that's what made the X60D so attractive while it was still around. literally only the top 15-20% of the battery you didn't have access to, that was the only difference.
  4. rainforest
    rainforest Member
    Vancouver
    That's incorrect. 75D had a slightly higher top speed as well.
  5. zackmilo
    zackmilo 2.2M+ Youtube views on my Model 3
    Los Angeles, CA
    True! I feel like 0-60 is faster than 6 seconds though on my X60D. Maybe Tesla underrated it..\
  6. MXWing
    I felt there was a minor difference somewhere but I couldn't point it to what. Thought I was crazy.
  7. outie
    outie Active Member
    SoCal
    • Helpful x 3
  8. MXWing
    That screen "capture" could be different depending on when you took it.
  9. zackmilo
    Los Angeles, CA
    I like how it says EPA EST. for 60D and EPA for every other trim
  10. outie
    outie Active Member
    SoCal
    That was when the 60D was first announced in July before official EPA #.
  11. zackmilo
    Los Angeles, CA
    OK. Thanks! How is your 60D doing? What is your 100%?
  12. outie
    outie Active Member
    SoCal
    My 100% is 100% ;)
    I have my battery indicator displayed as percentage indicator as I never pay attention to the rated miles which is largely inaccurate in my local drivings anyways.
  13. zackmilo
    Los Angeles, CA
    Maybe I should start doing that. Just multiply percent by 2 and you have your rated miles.
  14. nikeykid
    nikeykid Member
    Fremont, CA
    my 100% started at 202 miles, and after 10k miles is down to 198.
  15. zackmilo
    Los Angeles, CA
    Just hit 10k miles. At 199 at 100%.
  16. Peteybabes
    Peteybabes redneck drivin' a tesla...
    'murica
    can't believe that 60D owners would ever see a decrease, as its simply pulling from a 75D battery pack...
  17. zackmilo
    Los Angeles, CA
    I don't know why. Maybe need to do a stabilization or whatever it's called
  18. Yinn
    Yinn Active Member
    Behind you
    The display changes, the decrease may not be real. My 75D has read anywhere between 231 and 239 at a 100% charge. It's not a consistent trending decrease or increase.
    But in reality the battery would need to significantly degrade to start affecting a 60D.
  19. Gol4
    Gol4 Member
    San Jose, CA
    I remember seeing some difference in torque rating. Just found this article that talks about that: Lowercase x: Tesla Launches Lower-Priced Model X 60D
    "The P60D can accelerate to 60 mph in the same 6.0 seconds as the 75D, although its torque rating is listed as 325 lb-ft instead of 387 lb-ft. Top speed is limited to 130 mph, as with the 75D, while top 90D and P90D models hit 155 mph."
  20. mike2016
    mike2016 Member
    Los Angeles
    My X 60D at 100% has been at 192 miles max , since months ago... did the 75d upgrade today, 100% = 225 miles
