Model Y aftermarket suggestion
Hi all,
I have my 2021 Model Y that came with OEM rims and tires. Since it was in the middle of winter I put brand new Michelin X-Ice tires on OEM wheels and saving original tires for some nice rich-look fat fancy rims but I got lost here...
I would like to specifically buy Direct Fit (no ring adapters, using OEM lug nuts, etc.) "Black Widow" rims for my Model Y but not all of the OEM specs quite match to desired rims.
OEM rim specs are:
*Size 19x9.5
*Bolt pattern 5x114.3
*Center Bore: 64.1
*Offset: +45
*OEM Tire Size: 255/45-19
...so now my questions are:
1. Can I go with narrower rim, like 19x8 or 19x8.5?
2. If I go with bigger Center Bore I would have to use ring adapter, correct? I assume I can't go with lower Center Bore, correct?
3. How much can I deviate in terms of offset to be safe (5mm, 10mm, etc.)?
Your answers/suggestions/ideas are greatly appreciated.
Thank you!
jcanoe
5,566
6,127
Maryland
You also need to consider the Tesla Model Y gross axle weight rating (GAWR), tire load index when fitted with 19" wheels.
GAWR (front) for all wheel sizes: 3005 lbs
GAWR (rear) 19" wheels : 3607 lbs *
GAWR (rear) 20" wheels : 3307 lbs
GAWR (rear) 21" wheels : 3505 lbs
19" tire load index 104 (1984 lbs) *
20" tire load index 101 (1819 lbs)
21" (front) tire load index 98 (1653 lbs)
21" (rear) tire load index 103 (1928 lbs)
* If you use narrower 19" wheels the weight rating must be at least 1804 lbs per wheel; tires for the narrower wheels need to have a load index of 104.
Reactions: Puma2020
