There are 8 different spring part numbers and 5 different damper part numbers. (The rear suspension is not a strut/spring assembly, they are separate.)
Some of them I can figure out what they go to, the Performance or RWD variant, others I have no idea:
Dampers:
Springs:
In some cases they list two revisions for a given part, but what is the difference between the "LOW" and not "LOW" versions of the springs? (Is the low one softer?)
What do the xx-yyyy numbers mean on the parts?
Based on the front part numbers I assume the "SP" dampers are for Austin made Model Ys. (Austin appears to use different front damper/spring assemblies.) Maybe only for the non-long range variant. And then based on the part numbers the "81-7300" springs would be for Austin Model Ys as well.
