Model Y charging keeps stopping
Bill Dolby
New Member
Nov 14, 2020
3
0
Los Altos, Ca. 94024
In the last week, my Model Y has 'stopped charging' repeatedly. It charges for 3-9 miles, and then stops again. I've checked the plug into the car to make sure its all the way in. I've reset the circuit breaker for my Gen 3 home charger. Sometimes I can get it going again on the mobile app by pressing 'start charging.' But it doesn't always work. Is anyone else experiencing this frustrating problem?
rick1906
New Member
Sep 6, 2020
4
3
Flossmoor, IL
I'm having the same problem too. I had that problem a couple of months ago and it stopped, but now it's doing it again. I've rebooted and reset the breaker but nothing helps. I'm guessing it's related to a software release. I have a mobile service appointment for next Friday too.
Rockster
3,007
4,611
McKinney, TX
I had a gen 2 charger that did that. It turned out to be a loose connection inside that had melted the terminal block. I had to replace the charger. I know the gen 3 units have been experiencing some flakiness of various types, so obviously it might not be a loose connection in your case.
GeezerSquid
Still a Geezer & Still A Squid
Jun 17, 2020
85
113
Baton Rouge, LA
My Y starting doing after a month of working perfectly with my Gen 3 Wall Connector. Turned I that I had failed to porperly "Commission" my Wall Connector. Seemed to be just getting it properly connect and setup wtih Wifi. They sent me text with a link to instructions. Easy peasy - issue gone. YMMV
user212_nr
1,407
732
US
Try setting the car to charge at a lower amperage.
The gen3 has had overheating issues, as well as it could be misconfigured or wrongly installed (as some have mentioned). Also make sure it is connected to wifi and has latest firmware.
"charging stopped" is a general issue and not necessarily the same problem in all cases of it.
MrWattson
116
63
Central NJ
I just posted a similar thread (did not see this one). I have had my MY only a few days but have experienced the 'stopped charging' issue several times. I am, however, just charging on 110v for now. Should have my home charger installed in next week or two.
RobDeBank
50
7
Lancaster PA
Had the same issue with my Gen 3 charger. Called customer support who can remotely see my car, told me it was an issue with the charger not the car. I made sure the charger was connected to the WiFi. They sent an update and to date it seems to have fixed it. So if you have issues call CS and make sure your charger is connected to your WiFi to get the latest firmware. Hope that helps
Reactions: MrWattson
Rocky_H
5,848
6,684
Boise, ID
I'm usually the guy irritated at people going around correcting everyone on this when it doesn't matter, but when discussing a diagnosis of which piece of equipment has a problem, that's the time that the terms do become relevant. The charger is the thing in the car. That is the wall connector that needed the update. I know, I know...stone me now.
Jacopa
76
47
Conn
Decaf maybe? Sorry, couldn't resist, ;)
Reactions: RobDeBank
Rocky_H
5,848
6,684
Boise, ID
Hey, I'm not the guy who created an entire thread just for the purpose of screaming and ranting about this terminology issue:
It's A Wall Connector!!
And when people are posting questions about whether a hotel will let you use their "charger" or asking if there are good "chargers" available in Seattle or something, I will never bring it up then, while some others make pests of themselves to correct people about it. It just doesn't matter then. But I was just relenting that this is the kind of scenario where it's finally worth saying something about it.
MrWattson
116
63
Central NJ
Sorry if this is a dumb question but how does one confirm whether their wall connector is connected to wifi for updates? My electrician installed mine. I never thought of it until now. I did try to research and went to the QuickStart brochure and scanned/read the QR code from my mobile phone. It 'appeared' to scan the code but that was that. No confirmation, message, etc. Just returned to the previous screen.
