Model Y excessive battery drain
drtimhill
1,551
1,836
Seattle
Regen set to low. Going to try and use standard mode for this to see if it helps.
I do not have the Summon feature, or at least don't see that on the Control screen. I did not opt of the $8k Full Self Driving Capabilities, which I think includes the Summon feature.
Thanks,
--MJK8
You really need regen on standard . why did you set it to low?
MaJeK8ball
18
This is a common concern by owners that check miles achieved vs. miles estimated.
Usually find the they have something turned on like security cameras, automated interior cooling, or are not realizing your car uses some juice just sitting in the garage. They don't realize it uses additional juice when cooling or heating a car multiple times with short trips between.
All sorts of thing effect battery efficiency.
If you really want to "test" your consumption, take one longish trip with reasonable speeds (55) and use cruise control as much as possible. This is the condition that EPA ratings are calculated.
Doing lots of short trips, and adding up all the miles used will most always result in more juice being used than the gauge indicates.
After a while, new owners quit obsessing about these thinga and learn to just enjoy the ride.
Uncle Paul,
I would be ecstatic if I were averaging 300 Wh/mi. (My avg is 379 according to Tesla). I can't enjoy the ride when I'm charging up after only 130 actual miles when I should be getting at least 225 at a minimum.
I don't lose much mileage when the car sits in the garage overnight, maybe 2 miles, usually just 1 mile ticks off. Battery gauge drops like a rock once I start driving. It doesn't matter if it's a short trip or longer trip. Averages about the same of me getting about 52% of the battery's range, which, IMO, is unacceptable.
drx10
67
32
Maine
Here's a snapshot of my last 13 miles drive using the 15 mile range energy graph.
Trip was 6.5 miles one way (13 round trip) with abot 3.5 of it on a highway never exceeding 60 mph. A/C set to 72 with fan speed on 5
Regen on standard All other functions such as sentry and overheat turned off.
Started w/ 143 on the battery gauge and ended w/ 122 miles on the battery read out. Lost 21 miles on the battery for a 13 mile trip, which is a little better than what I was averaging. I did sit in traffic with about 2 miles left on the trip. View attachment 584489 .
Can anyone help me and determine what it going on here?
The entire trip I'm well above the ideal Wh/mi of 260.
Your Wh/mi of 448 is insanely high. If your driving style isn't crazy, I do wonder/worry if something in your car is not right. Maybe something is on that is consuming a lot of energy? Maybe something is faulty and abnormally using higher than normal energy? Maybe regen braking is faulty and it isn't regenning for you?
I dunno, but it seems like you're onto something. Overall, the Wh/mi on that screenshot is def above avg.
MaJeK8ball
18
I don't really like how the vehicle drives when on standard regen, but will do it if it helps with the range. I just did a 13 mile trip w/ regen on standard and no change to the efficiency.
Battery consumption is still too excessive even for driving with regen on low. I don't think I should be losing 48% of the battery's range b/c the regen is set on low.
Do you?
MaJeK8ball
18
drx10,
Thanks for the help. My appt w/ the Tesla service center can't come quick enough for me. I'm stressing out about it. A +$50k vehicle should not be giving me stress. I should be enjoying it Right now I feel my Y is a POS and I got ripped off and Tesla doesn't seem to care much. They're telling me my vehicle is "operating without fault".
If the service center tells me everything is fine, I'm getting rid of the vehicle.
MaJeK8ball
18
Do you have a friend that has a Tesla? Maybe have your friend drive your car and you drive his/her's and compare.
Good suggestion, unfortunately I'm not close to anyone that owns any model Tesla.
I'm going to use the vehicle as little as possible and wait and see what the service center says next week.
Wennfred
2,915
1,821
San Diego
Your wh/mi is very high for 65 mph average. mine is 274 - 300 and that’s at 70 mph, those Uber wheels are very heavy at 68 Lbs each but once you start rolling that shouldn’t be an issue unless you have lots of up hills in your commute.
The next time you go for a ride and park, lightly touch your Rotors, they should be cool to the touch. If they are hot then the brake pads are dragging against it. There hasn’t been any issues with the caliper glide pins getting stuck but with a wh/mi of what you posted 379 that’s a concern.
Next long 20 mile trip set your regen to low. This will allow the ride to roll and not cause you to step on it to get it moving hard again. 68 Lbs per wheel takes A lot more force to get the car moving.
One last thing you can do to prevent jack rabbit starts and to lessen Voltage lag is to set it to Chill mode. This will reduce the initial stress on the battery when starting to move also.
Hope that helps, to us 379 wh/mi is going pretty fast, if you’re saying you are keeping it at 65 and not punching it, then there has to be something else going on.
Fred
drtimhill
1,551
1,836
Seattle
Do you?
No, I don't, but I also don't think there is single cause here .. probably just an accumulation of smaller causes, including regen. Force yourself to drive with standard regen for 3-4 days, you will get used it quickly, and it does make a difference, though as you note its not massive (it also makes one-pedal driving a reality, which is super-nice once you get used to it).
MY-Y
823
871
MD
Make sure you are measuring a round trip. The weather was nice today, so i didn't need the AC, and there was some traffic that helped with the wind resistance and dropped my speed some. Going to work is downhill, so I only used 176 Wh/mi. By the time I got back home, it was at 209 Wh/mi.
Going to downhill to work.
Round trip. (Took the back roads home, so my round trip was a little better than my normal highway 230 Wh/mi.)
If all my driving was a nice smooth good weather commute (Covid traffic is still light), I'd have a 74000/209=350 mile range. My lifetime average, which includes the heavy-footed honeymoon period, is 247 Wh/mi. This is a 74000/247=300 mile range, and is slowly improving.
Reactions: MorrisonHiker
Brown1428
137
244
Georgia
What are your tire pressures?
BEV10
New Jersey, USA
I agree with others that your energy consumption wh/mi is unusually high. I just took a long road trip (>4hr) last week, and I got ~280wh/mi at mostly 75mph highway speed. I ran AC at 72F (with outside temp at 85-90F) with tire pressure of 40psi. I have a Model Y LR AWD with 19" Gemini wheels. The difference between standard and low regeneration shouldn't have that much of an impact on energy consumption for your short trips. Something else is going on if it's not your brakes acting up.
MrTemple
105
181
Pacific North Wilderness
You almost certainly do live near another Y.
There's a big Model Y FaceBook group. I’m sure somebody (maybe even a MYP owner) would be willing to help.
MorrisonHiker
S 100D 2021.4.12
Mar 8, 2015
9,203
8,338
Colorado
How often are you using the brakes? If you still use the brakes as you did on an ICE car, that will greatly reduce regen, especially if you don't have it set to Standard regen.
I rarely use the brake pedal unless it is for an urgent stop. 99% of the time, I can just take my foot off the accelerator.
