As stated, it was pre-conditioning for a full 30 minutes attached to the charger (40amp/240V). The heat provided was slow to come up. I double-checked that the heat system was set to "Auto" so it could adjust settings fully as well.
I would be interested to see the number and such although it would be anecdotal for me. Thank you.
Original poster might have an issue with the heat pump or something in the HVAC system if it's not warm after 30 minutes inside the car. There have been reports of other Y owners with similar issues.
Here's the information since it might help others learn the pre-conditioning process.
Attached is a graph to show an 18 minute pre-condition. Sorry for the low quality, I have to figure out how to get a decent image since it seems the Snipping Tool I'm using is causing some resolution loss.
* Outside temperature 26F, temperature inside my garage 47F, as shown in green.
* Front Stator motor started at 62F, shown in blue.
* Rear Stator Motor started at 62F, shown in pink.
* Battery inlet temp started at 51F, shown in red.
* Cell Temp Mid (battery pack) started at 52F, shown in black.
Right around the 1 minute mark you can see the red line (battery inlet temp) drop. What's happening is the Octovalve directing more of the heat to to the heat pump to heat up the cabin. My Y gets warm fairly quickly, usually within 5 minutes.
You can see the front and rear motors quickly warming up with the front motor being warmer while the vehicle is parked. The highest I've seen the front motor get is 210F. What's happening is the refrigerant is passing by the motors and the heat is picked up via conduction. The Octovalve is then distributing the refrigerant, as needed, so initially some of the heat is sent to the heat pump to warm the cabin, and then routed to the battery pack. As long as the battery inlet temp is greater than the battery pack temp, the battery pack will warm up. The reverse is true, if the inlet temp is lower than the pack temp, the battery will go down in temp.
After 18 minutes:
* Front Stator motor started at 62F, finished at 190F
* Rear Stator Motor started at 62F, finished at 162F
* Battery inlet temp started at 51F, finished at 75F
* Cell Temp Mid (battery pack) started at 52F, finished at 69F
