Tesla has designed the 3 and Y motors to create a non-motive power waveform to produce heat in the stator motor.
It's pretty amazing how fast the motors warm up, as shown in my previous graph.
What I didn't post (since it didn't apply to the previous questions) was the graph of the motor and battery pack temps after the preconditioning. Here's the graph showing the various points of data for a 33 minute drive.
Weather conditions were pretty bad, 26F, roads were icy with packed snow, and further into the drive it got a little better with mostly wet and slushy roads. Here are the stats from the drive:
* Front Stator motor started at 190F, finished at 77F
* Rear Stator Motor started at 162F, finished at 95F
* Battery inlet temp started at 75F, finished at 61F
* Cell Temp Mid (battery pack) started at 69F, finished at 67F
* Car set to Chill mode, low brake regen. Topography fairly flat.
The car was able to maintain the battery pack temp for about 10 minutes since the front and rear motors (blue and pink line) were above 100F during that duration. You can also see the battery inlet temp (temp of the refrigerant prior to going through the battery pack) dipping at around the 10 minute mark. This was when I turned on the heat for a little bit, so the system pulled the heat that was originally directed to the battery to go into the cabin. Visually you can see on the red line when I did this.
The car has a lot of amazing tech going on in the background. Most owners will never realize what's going on and take the design and tech for granted.
