Model Y hitch receiver tolerance.
Discussion in 'Model Y' started by Jarret, Mar 2, 2021 at 2:32 AM.
  1. Jarret
    Jarret Member
    Tuesday
    I got the factory installed tow package on my model Y. I have tried 4 different hitches and all of them are so sloppy lose that they bounce up and down inside the receiver. So when I hit bumps my trailer slams up and down along with the hitch and it is really loud and can't be good for the equipment on the car side or the trailer side. Anyone else notice this? 132548670_2867406926823069_2273273745705.jpg 132796259_2866792393551189_9713195937003.jpg
  2. Midnightsun
    Midnightsun Member
    Canada
    Pretty much normal for any reciever IMHO. No way can it be made tight enough to eliminate rattle and when they do get tight, a little sand or corrosion makes then difficult to insert/remove. Not sure if this fits the Tesla but if it does it may be a good solution for you.
  3. Midnightsun
    Midnightsun Member
    Canada
  4. Jarret
    Jarret Member
    Tuesday
    I've owned/towed with at least a dozen trucks. I have never had this problem before. And the hitch clamp wont fit on the Model Y because the receiver is inside the bumper with no spare room. Just seems like shoddy engineering.
  5. patnshan
    patnshan Member
    Milwaukee, WI USA
    My MDX hitch rattled a lot as well. I put one of those tighteners on and it worked great. The problem with that is they are cumbersome to put on and take off if you don't plan to leave the hitch attached to the receiver all the time (I do not).
  6. Koolio46
    Koolio46 Member
    Boston, MA
    Haven’t used my factory installed hitch yet but the only hitch receiver I had that wasn’t loose was the factory BMW hitch from my 2012 X5. That hitch was great. The factory Audi hitch I had on my 2018 SQ5 had some slop in it, wasn’t terrible but noticeable coming from the X5 hitch.
  7. MattinCO
    MattinCO New Member
    Colorado
    Based on my experience, I think it's somewhat normal for unibody vehicles to hear that noise in the cabin, doesn't make it any less annoying though. With body on frame trucks, there are rubber isolators between the frame and body that dampen that noise.
  8. Midnightsun
    Midnightsun Member
    Canada
    Exactly and this is what he mentions in the video. As you can see on his GMC pickup truck the slop is there for sure. Would not be so quick to blame the slop on the receiver as the draw bar/accessory being inserted into the receiver can vary quite a bit. No way can a trailer connection be silent unless the tongue weight is rather large preventing it from moving around.
  9. Jarret
    Jarret Member
    Tuesday
    I tried the 3 draw bars that I had for my truck. All of them are tight in the truck. All of them have 3/4" of an inch of wiggle up and down on the Tesla. I also ordered a brand new bar and it is the same story.
  10. Inteltraveler
    Inteltraveler Member
    Scottsdale, AZ
    @Jarret What is your range impact towing the SxS? I plan on towing mine often once I get the MY and curious what this looks like.
  11. Jarret
    Jarret Member
    Tuesday
    I am getting about 50% of what I get without the trailer. My trailer weighs 770lbs and the RZR is 1450. I think I lose a lot of range because I have the fold down ramp which acts like a parachute at the end of the trailer. I am considering making it removable.
  12. Jarret
    Jarret Member
    Tuesday
    On a side note, the safety chains of the trailer bounce up and down on the bumper so they are breaking the bumper. It appears the engineers have never towed or owned a trailer.
  13. Koolio46
    Koolio46 Member
    Boston, MA
    Ugh, that sucks. I’m thinking of wrapping the chains in a microfiber cloth (using zip ties). That should help
  14. Coloradogramps
    Colorado
    I got one of those for my hitch, and it works great, eliminates all the rattle. This type of rattle is common in all hitches, so this simple solution is helpful.
