Just saw this..... How is this possible? Incredible really.
I
posted about this already. But your comparison is to vehicles with stickier tires - makes a big difference with high MPGe. For the AWD Model 3 it is not a fair comparison as that vehicle is less efficient, probably due to a lower capacity rear inverter. The Performance Model 3 18” is voluntarily derated and is actually considerably more efficient than stated (it
says Performance in your comparison but those are actually AWD numbers). Also, as far as I can tell, they are using an arbitrarily higher scalar to convert 2-cycle results to 5-cycle results for Model Y. And this affects the MPGe.
The actual dyno results are considerably worse for the Model Y - especially on the freeway, as you would expect. See the post for details. We will wait for the full EPA submission to get the numbers exactly right (I was not able to get perfect alignment). But we already know Model Y is not as good as Model 3, just looking at the raw UDDS AER CARB executive orders.
Here is the raw data from the EPA datafile. The orange is the raw efficiency from the dyno test. You can see that on the highway, where range matters, except for the Performance Model 3 with 20" wheels (which is about the same), it is more efficient than Model Y. The Model 3 Performance with 18" wheels is
15% more efficient on the highway cycle! The other numbers are scaled versions. They multiply the mileage by a scalar to convert from 2-cycle to 5-cycle (usually 0.7 for most manufacturers) to arrive at the final result (only EVs are allowed to do 2-cycle testing AFAIK). But Tesla uses a value that is about 7% larger for the Model Y. So that makes the miles 7% higher in the final label.
