Model Y not sleeping when charging
Discussion in 'Model Y: User Interface' started by Juanpelota, Feb 16, 2021.
  1. Juanpelota
    Juanpelota Member
    US
    Hi
    -5 yr Tesla driver, northern climates. Went out this morning to unplug the 2020 model Y, and the screen was in some sort of panic mode...charger maps zipping all over the pace.. with the cabin heat at 70F. (was 6F outside). Had been blowing heat all night like that.
    First time occurrence. No changes in bluetooth app settings, cabin heat protections, etc..
    Soft reset seemed to work.
    Any opinions on what the issue was? Any similar experiences?
    thanks in advance,
  2. mark95476
    mark95476 Member
    Bay Area CA
    Post a pic of your screen.
  3. jcanoe
    jcanoe Active Member
    Maryland
    Did you accidentally leave the phone or the key card in the Tesla? Normally when you open the driver's door the HVAC will shut down. Is it possible someone touched the HVAC controls and set the climate control to be On after exit?
  4. mariod
    mariod Member
    Toronto
    We've had our model 3 stay unlocked randomly for no apparent reason. It does happen, but not often.
  5. frankvb
    frankvb Supporting Member
    San Diego, CA
    I'm experiencing the car frequently not going to 'off' when exiting and closing the driver's door, opened a service request. Screen stays on, showing all doors closed. I'm now in the habit of checking this every time I exit the vehicle. Patch is to open and close the driver's door again, that usually works, very occasionally needs a few retries.
  6. Juanpelota
    Juanpelota Member
    US
    thinking indeed it was a softly closed door.... has not repeated. thanks
  7. madmax240
    madmax240 Model S 100D
    Russell, Ontario
    If I remember correctly, for the car to sleep, you need to power off on the screen if you want to force it.
  8. GtiMart
    GtiMart Member
    Quebec City, Canada
    @frankvb , I get this sometimes as well. It seems to happen when I move my car in my driveway without putting on my seatbelt, or when stopping for the mail and driving the remaining 300ft to my parking without my seatbelt. (I know, I should put it on for that second case...). I think the car has trouble figuring out that you're done driving when you don't buckle up. There might be other cases but that is definitely one. I haven't done a service request yet because I was gathering evidence first. It's easy to see when it happens as the driving lights stay on in that case (DRL, in Canada).
  9. frankvb
    San Diego, CA
    The tech that came and replaced the door latch, mentioned that the aftermarket puddle light may cause this.
    I swapped the light with another door to see if that makes a difference. Hasn't re-occurred yet, but sometimes it worked ok for a few days.
