Curious as to why you say lowering springs are bad in the context of a HV battery.That said, lowering springs are bad news in the context of a HV battery. If you want the lowered look look at a proper set of coilovers.
You don't want the HV battery closer to the ground unless you can make sure it won't impact the ground. Lowering springs kind of suck in general and I think with an EV it just makes the equation even worse.Curious as to why you say lowering springs are bad in the context of a HV battery.
So why would coil overs be any better?You don't want the HV battery closer to the ground unless you can make sure it won't impact the ground. Lowering springs kind of suck in general and I think with an EV it just makes the equation even worse.
The damper's valving is made to match and is adjustable for lowered height, ie. one can increase low speed bump so it doesn't bottom out.So why would coil overs be any better?
I would not expect that 3 & Y springs are different … but in the smallest measurements… spring rates or # of coils or things we cannot visibly see.
On the battery closer to the ground front - all of my cars are lowered… EVs and ICEs… all of my battery packs and oil pans have less clearance. It’s the game you play.
Do not do this, you will cause serious damage or injury. The suspensions are very similar but made to different lengths heights and weight requirements.
This is kinda where I was going. Recycle the M3P springs into the Y, achieve a slightly lower stance in my wife’s Y. The 3 is going to bags.Yep - bump stops are there for a reason, but all of my vehicles are 1” dropped from stock. So not on the ground - and stock shocks work… not awesomely… but they work. Ride quality is didn’t change from stock. If I could afford (need wife’s approval) the $3-4K for actual coilovers… I’d do it in a heartbeat! Sport springs/drop springs are always a compromise, especially w stock dampers.
