On my MYP with Uberturbines, I would probably expect around 180~200 miles running it down to close to 0% with your stated conditions. I'm not certain about the effects of the 95+F temps though. If the AC is working hard I'd probably expect a bit less range. So what you're seeing is fairly normal in my estimation.I just finished a 2000 miles trip on my MYP 2022. I have 20" wheels on it that are lighter compared to the original wheels. Maybe is something wrong with my car but with two people on the car and the luggage I could not beat 200 miles range on a full charge. I end up charging between 100 and 160 miles which is lame. I really wanted to get to 200 miles on a 85%-90% charge. The average speed was 70-75 mph and the AC was running on AUTO. The average temperature outside was 95+ F. Any thoughts?
Thank you! I hoped for 240 miles range on a full charge.On my MYP with Uberturbines, I would probably expect around 180~200 miles running it down to close to 0% with your stated conditions. I'm not certain about the effects of the 95+F temps though. If the AC is working hard I'd probably expect a bit less range. So what you're seeing is fairly normal in my estimation.
You need to look at your wh/mile. Sounds like you were probably around 325 to 340 wh/mi which is pretty normal for 75 mph with AC on and maybe some light wind here and there. I do about 70 mph and will see just around 300 wh/mi if there is no wind. The faster you go the more energy you use, 80mph is much worse than 70mph, etc.I just finished a 2000 miles trip on my MYP 2022. I have 20" wheels on it that are lighter compared to the original wheels. Maybe is something wrong with my car but with two people on the car and the luggage I could not beat 200 miles range on a full charge. I end up charging between 100 and 160 miles which is lame. I really wanted to get to 200 miles on a 85%-90% charge. The average speed was 70-75 mph and the AC was running on AUTO. The average temperature outside was 95+ F. Any thoughts?
You actually should be able to get very close to that.... but do you want to risk it? That likely would be 100% down to 0% (based on about 80kWh battery, it may actually only be around 77kWh usable... either way that would need to be about 330wh/mi if it's 80kWh usable or 320wh/mi if it's 77 usable. Again, are you actually driving down to zero though, or are you pulling in around 10% battery? If you're going from 100 to 10% than you are only using 90% of your battery and are looking at more like 225 miles of range or maybe 200 to 210 if there's some wind.Thank you! I hoped for 240 miles range on a full charge.
My average was 305 over 700miles.You need to look at your wh/mile. Sounds like you were probably around 325 to 340 wh/mi which is pretty normal for 75 mph with AC on and maybe some light wind here and there. I do about 70 mph and will see just around 300 wh/mi if there is no wind. The faster you go the more energy you use, 80mph is much worse than 70mph, etc.
700 miles at highway speeds, or mixed driving?My average was 305 over 700miles.
I get 230 miles with 90% charge. I-95 and speed between 80-100 mph (depending on traffic). A/C with lowest temperature with fan speed 6 for entire trip with 2 adults and two kids with two aluminum framed car seats with full of luggage in the back. With OEM 21" Ubers with Micheline AS4 tires.I just finished a 2000 miles trip on my MYP 2022. I have 20" wheels on it that are lighter compared to the original wheels. Maybe is something wrong with my car but with two people on the car and the luggage I could not beat 200 miles range on a full charge. I end up charging between 100 and 160 miles which is lame. I really wanted to get to 200 miles on a 85%-90% charge. The average speed was 70-75 mph and the AC was running on AUTO. The average temperature outside was 95+ F. Any thoughts?
The Tesla vehicle range estimate now factors in temperature and weather (wet/dry) conditions in addition to posted speed limits and elevation changes on a route. Tesla continues to use the vehcile's EPA combined City/Highway energy consumption as the reference.I think the software predicts range based on driving habits too.
Ours seemed to do a bit better than that. Brand new MYP. We just completed a 1700-mile trip yesterday. 21" Uberturbines, stock Michelins. 2 adults + 2 kids & car seats in the car, frunk packed full, sub trunk and cargo area full to the roof with strollers, pack and plays, and luggage, 40lb cooler with ice. 96-103+ degrees for the entire drive. 95% freeway, 75-85 mph set on TACC for the majority of the miles. The entire trip average on-screen shows = 336 Wh/m (including about 80-90 miles around town driving at the destination for the week (most of that in town time was 450-500+ Wh/m in traffic). Heavy downpours for about 60 miles on the freeway. Thought it would be even worse with the car loaded to the max and driving 80mph + most of the trip with AC on 6-8 the entire time. Most of our segments were around 170-190 miles between charges and we never went below 12-15% or above about 85-90% charge for the entire route. Usually, we were between 20-80% charging since this was our first trip in the car and we had no idea what to expect and didn't want to push it. 200miles for us at 90% charge and 80+ mph would have been easily doable in our loaded-down car. However, even averaging 336 wh/m, it wasn't an issue at all for us, people needed to stop for bathroom breaks or eat regardless, and the timing for stops worked out nearly perfect for us.I just finished a 2000 miles trip on my MYP 2022. I have 20" wheels on it that are lighter compared to the original wheels. Maybe is something wrong with my car but with two people on the car and the luggage I could not beat 200 miles range on a full charge. I end up charging between 100 and 160 miles which is lame. I really wanted to get to 200 miles on a 85%-90% charge. The average speed was 70-75 mph and the AC was running on AUTO. The average temperature outside was 95+ F. Any thoughts?
How long did it take to charge the vehicle at the rest stops you had made on your trip?Ours seemed to do a bit better than that. Brand new MYP. We just completed a 1700-mile trip yesterday. 21" Uberturbines, stock Michelins. 2 adults + 2 kids & car seats in the car, frunk packed full, sub trunk and cargo area full to the roof with strollers, pack and plays, and luggage, 40lb cooler with ice. 96-103+ degrees for the entire drive. 95% freeway, 75-85 mph set on TACC for the majority of the miles. The entire trip average on-screen shows = 336 Wh/m (including about 80-90 miles around town driving at the destination for the week (most of that in town time was 450-500+ Wh/m in traffic). Heavy downpours for about 60 miles on the freeway. Thought it would be even worse with the car loaded to the max and driving 80mph + most of the trip with AC on 6-8 the entire time. Most of our segments were around 170-190 miles between charges and we never went below 12-15% or above about 85-90% charge for the entire route. Usually, we were between 20-80% charging since this was our first trip in the car and we had no idea what to expect and didn't want to push it. 200miles for us at 90% charge and 80+ mph would have been easily doable in our loaded-down car. However, even averaging 336 wh/m, it wasn't an issue at all for us, people needed to stop for bathroom breaks or eat regardless, and the timing for stops worked out nearly perfect for us.
Most stops were planned onscreen for 15 - 25 minutes, 35 was about the longest (planned) stop we ever did. Most of our stops were at 250kW chargers with nobody parked next to us to slow it down. We usually weren't even done with what we were doing when the car was ready to continue so we overcharged an extra 5-15% at most stops due to eating/reloading up 2 kids in car seats etc.How long did it take to charge the vehicle at the rest stops you had made on your trip?
