so here is what I did as soon as I got the car:
I switched the tires from stock to Michelin All Seasons:
Front stock 255/35/21 to 265/40/21
Rear stock 275/35/21 to 285/40/21
Here is the thread documenting everything:
Hi All, Trying to figure out the clearances to avoid rubbing. Have the performance and wanted to add a little more cushion (wider, taller tire). I cant find the clearance data on the suspension components. Would love to hear if anybody thinks the following setup will rub. Uberturbines: Front...
teslamotorsclub.com
I had tiny, tiny, tiny rub on the liner when turning the wheel, but after 1000 miles that is now gone. I would absolutely do it again and I think the diff in speedometer error is 4%, so marginally nothing. It gives me enough sidewall for the nasty NYC streets and have not had a dent /scrape / chip as of yet. In my opinion, there should have been the tires that Model Y P came with from the get go. I think from the brief tests I have done the efficiency was the same or even better than the stock tires.
