1,233
503
The Tesla Model Y received an official rating from the Environmental Protection Agency, with the Performance variant certified for 315 miles of range. The rating bests even Tesla’s target range, placing the Model Y’s efficiency ahead of all non-Tesla EVs on the market. “Due to continued engineering progress of the Model Y all-wheel drive (AWD),...
[WPURI="https://teslamotorsclub.com/blog/2020/02/07/model-y-receives-epa-rated-315-miles-of-range/"]READ FULL ARTICLE[/WPURI]
Aarons12
Enjoying my Pearl White LR AWD with inductions
Jan 24, 2020
391
177
long island, NY
there seems to be some confusion on whether the entire lineup was certified or just the performance model. your post doesn't clear that up. any additional thoughts?
AlanSubie4Life
Efficiency Obsessed Member
Oct 22, 2018
9,386
11,261
San Diego
This is presumably the one with the 19" wheels since the range matches the website. Also note that the Tesla website is ONLY providing an "EPA Est" for the Performance with the 198" wheels. The other ranges are just estimates so nothing official there yet.
Data here on how this compares...
Definitely looks like the Model Y is going to be a lot lower range on the highway than Model 3, but no surprises there. It'll be interesting to find out how they justified the larger scalar of 0.756 rather than 0.7032. Maybe there is actually real motivation (heat pump?) - but they also use large values for some of the Model S line, so not holding my breath. Would be better to just do a 5-cycle test though.
reardencode
230
825
Seattle, WA
I doubt Tesla is BSsing on the range relative to their other offerings. That'd be a PR disaster. More likely they have significantly reduced the accessory load in the MY by more intelligently providing cabin/battery/motor thermal management, and by reducing or eliminating the dependency on a 12V accessory bus.
I might believe that MY will be harder to get rated range in ideal weather conditions and much closer to rated range than M3 in freezing conditions.
Reactions: AlanSubie4Life
Sojournerman1
12
3
New zealand
Phantom3
66
56
Burlington
Sorry if this has already been asked or has an obvious answer, but will the model 3 aero wheels fit on the model y, and if so, will they give any additional range performance? I’ll be upgrading once my Model Y is available and contemplating keeping the aero wheels in the event that they increase the range for those long road trips.
AlanSubie4Life
Oct 22, 2018
9,386
11,261
San Diego
My understanding is that the Gemini 19" wheels are the appropriate aero wheels for the Model Y. 18" wheels won't fit the Performance brakes; no idea whether there would be other issues with them if that were not an issue. I personally don't know anything about the Model Y wheel offset or wheel width.
But in terms of benefits over the Gemini 19" - I would guess there is minimal benefit. Tesla's 315-mile configuration for the Model Y is likely highly aero optimized already (as you can tell by the projected 280-mile range for the Performance package).
Archon
23
26
Gilbert, AZ
In theory, it should work, as the Model Y uses the same bolt pattern as the 3. But in practice, the Y's suspension, TPS, and range calculators are probably tuned for the bigger 255 tires instead of the 235's you'd find on the 3. Also, the wheel wells are massive compared to the 3. In my opinion, it'd look a little comical to have tiny tires with a vehicle roughly the size of an X.
That said, nothing's stopping you, but AlanSubie4Life is correct, there shouldn't be that much of a difference between the Aero and Gemini. In fact, the Gemini's actually have more sidewall than the Aeros (114mm vs 105mm) and should have the same aerodynamic properties normally found on a plastic cap mounted on a light alloy wheel.
