Mice have attacked our Model Y. They have chewed on the firewall insulation and tore up some tissue paper in the cabin.Apparently, some Tesla models have had serious damage due to rodents. Does anyone know if the Model Y is as vulnerable?
I absolutely understand that rodents are problems for many cars. That doesn't mean that we must live with this. As a retired product designer, I know that there are professionals with the backing of capable manufacturers that can come up with solutions, especially if the kits are customized to particular models. I would gladly pay $300 and probably more if I knew that the solution was robust. I don't have a garage, and as Teslas come down in price, ungaraged Teslas will become common. People are spending thousands of dollars to fix rodent damage. This problem deserves a robust solution.Wow, I appreciate your pain but pack rats, squirrels, mice, etc... get into ALL cars regardless of make and cause extensive damage. Easiest solution is to park your car in a well kept garage. Lot's of people around here (who park outside) leave their hoods up at night, put lights under the hoods, etc... to combat the problem.
Anyway, good luck!
Rodents have attacked and invaded our Model Y. They have chewed on the firewall insulation and tore up some tissue paper in the center console in the cabin. I discovered the tissue paper evidence yesterday and, today, removed the maintenance panel to try to determine how the rodent got in. So far, I have some ideas, but nothing definitive. If there is anyone who has definitive information, please let us know. As a retired person who spent his career designing products, managing design projects, and doing extensive work to ensure quality in design and manufacturing (although not involving autos), I have no tolerance for automobiles that fall victim to rodents. No excuse! That said, we are now relegated to band-aids and anti-rodent potions. There are sprays that repel mice, so I sprayed one of these products all over the equipment and surfaces normally concealed by the maintenance panel except the top of the 12V battery. Although I found no damage, there are unprotected wires behind the 12V battery. One suspect entry point is through the cabin air intake. I cut wire mesh to go over that and cut a small piece to cover a drain hole in the bottom of the air intake. Does anyone have definitive information as to where the rodents are getting into the cabin?
