Model Y Service Bulletins
Discussion in 'Model Y' started by TDI Gromby, Sep 10, 2020.
  1. st50maint
    st50maint Member
    New York
  2. yerEVan
    yerEVan Member
    Near Philly
  3. Koolio46
    Koolio46 Member
    Boston, MA
  4. _bgd_
    _bgd_ Member
    NYC
    I’m curious about this too. Was looking everywhere but I can’t see these magic specs in writing from Tesla. I guess that’s why they’re called magic...
  5. skidmarc
    skidmarc Member
    Atlanta
    Anyone notice a TSB for the MY driver's mirror? On the forum for that topic someone mentions "Tesla Toolbox article #3114200?"
  6. tscollins2
    tscollins2 New Member
    Northeast U.S. of A.
    We have seen an issue with the heating system twice here in the NY/NJ/CT area. Once my wife was in the car and we had the heat set to 19.5C which was fine but after running for awhile the air coming out of the system felt cool instead of warm. My wife who is not a fan of the cold noticed at first and the solution was to turn up the heated seats. The second time I was doing a drive by myself to Philadelphia to visit family and again instead of warm air coming out of the system it felt cool. I just turned off the fans and put on a pair of gloves I had in my coat pocket. I do warm up the car for about 20 minutes before starting a drive via the app (Climate > Defrost) and so far every time we get in the car is warm so it is not like the system is completely broken. I haven't followed up with Tesla because getting a time slot at the nearest service center has not been easy.
  7. jcanoe
    jcanoe Active Member
    Maryland
    When driving for a time, after having preconditioned my Model Y, if the air coming from the vents starts to feel a bit cooler I raise the cabin temperature setting by 1 degree F and the air from the vent quickly becomes warmer. I find this is typical heat pump behavior; to provide air that does not not particularly feel warm but in reality the heat pump is operating efficiently if somewhat slowly in warming the passenger cabin.
  8. fparent
    fparent Member
    Cleveland
    I find the "auto" setting to be pushing an insufficient amount of warm air around the legs. I have to manually select both the upper and lower vents to be comfortable. This could be fixed with software.
  9. Alex Philips
    Alex Philips Member
    Spring, Texas, USA
    Agreed, I have this issue and have a Service Appointment Feb 9 for other issues and need this fixed too.
  10. davraker
    davraker Member
    Northampton, Ma
    I have this very same issue, VIN 50xxx. It heats up fine preheated, and also seems to work fine some of the time. But too often, especially when I’m on the highway, it begins to blow cool/cold air. Turning up the temp, doesn’t seem to influence this after it begins to improperly work.
  11. coleman567
    coleman567 New Member
    Houston
    The good news is it is relatively painless, they came to my home on Saturday and fixed it in less than 5 minutes.
  12. Sudsington
    Sudsington Member
    Chicago, IL
    In these cases of failure, some seem to be caused by faulty sensor(s) and can bediagnosed remotely: https://www.reddit.com/r/teslamotors/comments/lenrht/2021_m3lr_heat_pump_stopped_working/gmpavdr?utm_source=share&utm_medium=web2x&context=3 https://www.reddit.com/r/teslamotors/comments/lenrht/2021_m3lr_heat_pump_stopped_working/gmpimtf?utm_source=share&utm_medium=web2x&context=3
    • Disagree x 1
  13. Iceman23
    Iceman23 Member
    NJ
    Odd,
    my issue was the compressor and not the switches unless they didn’t post them as they were in stock?
    Parts Ordered
    1. AC Compressor, Model Y
      Part #: 1501256-00-I
      Order Date: February 15, 2021
    Please note: Parts required for your service that are available on site at our service center will not be listed here. Some parts ordered may not be installed during service if there is no fault found with the parts currently installed in the vehicle or if the parts are within Tesla standards.
  14. Daks
    Daks Member
    Anchorage, AK USA
    Getting the sensors which were remote diagnosed replaced tomorrow. Heat works until the temps get down into the teens F and it starts to get cold or blow warm. not hot air. Once temps break 0F it's like I have no heat. According to the Tech I am getting new sensors from a new vendor that according to Tesla engineers fixes the problem. Since I tend to get my head chewed off when I say the above - I will re-iterate, your own experience my vary. It's not all Ys, but a high percentage of a low number of total vehicles up here in Alaska have the issue. And Alaska weather is not your typical winter environment.
    My heat works even with the bad sensors if the outside air temp is above 20F. Starting out in a heated garage helps...
  15. enihill
    enihill New Member
    The Villages, FL
    Good to know. They are arriving on 23Feb21 to repair mine. Bad when new.
  16. HotIce
    HotIce Member
    MD
    Anyway to get the VIN list for the latest SB regarding the heating issue?
  17. jcanoe
    Maryland
  18. tshields
    tshields Vendor
    MIAMI, FL
    Not sure what is going on with the 2021 model Y as this is the third time in the last month I had to bring it in to Tesla for my A/C sensors. Also I just cracked up the front bumper and my local body shop is quoting me a price that is more than half of what Tesla charges would you rather pay double for a bumper replacement / paint to have Tesla do it instead?
