Model Y Stock Rear Window Tint
Klau2
398
228
Boyds, MD
I just had mine done with 25% tint. Only did the 2 front windows. My question is if anyone know if the back and rear are UV protected? Many tint shop advise to tint them with 70% tint. I didn't do it, figured I can always add them later.
Kuro Houou
458
279
I would love it confirmed, but I thought all car windows were UV protected due to the fact if you go on a long car ride you would get sun burn if not.
frankvb
832
507
San Diego, CA
I think it's not that straightforward.
Car door windows don't stop UV rays
I'd think that factory tinted windows (as opposed to aftermarket tinting) would block more harmful rays than clear windows, not sure if it's comparable with a good window film though.
Bigbear503
36
39
Bay Area, CA
No.. factory "tints" do not block UV rays or have any benefits with heat rejection. Its more for looks. Factory "tints" is just color dye in the glass. if you want UV protection and heat rejection, have a shop tint the rear windows
Reactions: Klau2
Klau2
398
228
Boyds, MD
Thanks for the info. I guess I'll go back later to get them tinted.
Georgia_Y
Closed
Feb 25, 2020
199
173
Georgia
The factory glass is dyed and not tinted with a film. I did mine with Llumar IRX 50 in the back and 15 in the front. They seem to match very closely.
Kuro Houou
458
279
Found this article interesting about UV ratings on car glass. It honestly depends on the car manufacturer as well but it looks like front windshields tend to prevent UV transmission more, due to the plastic in it. But for side windows it says they are typically only about 65% effective at blocking UV, or about the same as a SPF 16 rating..
That said, ended up opting to have all my windows (except the windshield and roof glass as Tesla and the nature of the glass/plastic laminate should prevent most all UV rays from coming into the cabin). I decided to do 30% up front and 45% elsewhere.. trying to match them as much as possible seeing as the back is already pretty dark.
Reactions: Klau2
Georgia_Y
Closed
Feb 25, 2020
199
173
Georgia
I would suggest looking into getting the windshield tinted as well. You can with 70% or so and it will appear just as transparent, but cut down on a lot of heat. Some of the newer ones can cut down on IR a good amount.
Reactions: Bigbear503
Kuro Houou
458
279
Maybe in the future I would consider it.. but honestly would want to see that in person first.. For me night driving is always a concern, its hard enough to see at night... really not trying to reduce that visibility anymore. But yeah, would be nice to cut down on at least half the heat coming through there even at 70%.
Klau2
398
228
Boyds, MD
The back are 25%, so if you want to match them you really should do 25%.
Kuro Houou
458
279
Unfortunately the tint only goes down to 30% at the place I am taking my car (getting Spectra Photosync), I'm ok with a 5% difference, will be hard to notice most of the time I'm sure.
Klau2
398
228
Boyds, MD
i see, but if you are tinting the back with 45%, that will make it even darker and the front 2 and back windows will have a lot more difference. Why not 70% in the back 2 windows? The UV protection isn't determine by the darkness of the film.
Kuro Houou
458
279
Right, UV isn't, but based on the info from the manufacturer it seems like the heat rejection is based on darkness some as well, about a 12% difference between 70 and 45.. maybe I split the difference at 55% ;) It does suck not having anything to really reference or look at.. kind of just guessing at this point.
Klau2
398
228
Boyds, MD
O cool, i was thinking they are the same. haha.
Wennfred
2,928
1,832
San Diego
These are the readings I got with the Tint meter (EDTM Digital Power Meter)
Outside Direct sun 254 (high)
Front windshield 95 (no tint)
Side front windows 50 (no tint)
Rear factory tinted windows 15
Roof glass factory dyed or tinted “5”
Rear hatch factory tinted 15
The Y is currently in the shop, getting Crystaline 70 on the front windshield and 35% on the front windows, I think it’s Xpel but will get the correct brand name when I pick it up. Will post new heat rejection numbers when I get it.
Fred
Reactions: Electric Steve
Dennisis
468
424
Tucson
Fred
So you're not adding to the top correct?
Dennisis
468
424
Tucson
Only adding the Front windshield and 2 front windows, everything else is covered already with factory tint.
Fred
Just checking, I plan to take mine in next week for full front PPF and tint, did the same with my M3 last year. Tinted the rear on the M3 though - I wonder if the MY tint is darker.
