Nobody has mentioned that radio traditionally uses "dynamic compression" ... a different thing completely to the data compression schemes that are used to make file sizes and streaming rates use less bandwidth. It's one of the the reasons TV adverts sound punchier even when you don't turn up the volume. Dynamic compression of music on the radio was/is partly to aid undistorted transmission and when there's not much dynamic range between loudest and quiet sounds such that the noise floor comes into the equation (analogue). It is/was also to allow for the fact that radio is often played on devices with small speakers that benefit from a bass boost. The chances are that
@teaston 's radio music comes with this dynamic compression, possibly even on DAB, but certainly on FM.
www.soundonsound.com
