The 6x12 was an enclosed cargo trailer. I believe the key to the numbers was keeping the speed at 55 mph.Was this a utility trailer or a cargo trailer? Based on your numbers, I’d have to think utility.
(Utility: open, cargo: enclosed)
That’s absolutely impressive. Those trailers are no joke. Thanks for sharing.The 6x12 was an enclosed cargo trailer. I believe the key to the numbers was keeping the speed at 55 mph.
Thanks for the report. I’m taking my MYP and an enclosed 4’ x 8’ U - Haul from Chicago to St Louis next week. The longest leg between Superchargers is 115 miles. I’ll keep it it at 55mph and hope it’s uneventful.The 6x12 was an enclosed cargo trailer. I believe the key to the numbers was keeping the speed at 55 mph.
What was your average watts per mile?The MY LR towed the 16ft scamp very well from the factory in Minn back home to Texas. We were able to get 170 -180 mi per charge but noramally stopped more frequently. I was keeping the speed at 60. So basically was hitting every super charger sort of do that anyway, just with the trailer I charge to 90 ~ 95 instead of the 75 ~80 w/o a trailer, and would come in around 10~15 %. Anyway it works great the free charge from the RV campground. Scamp is a fantastic little travel trailer and pretty aerodynamic. It isnt wider than the car, anyway if someone is looking for a travel trailer for the Y...I would recommend the Scamp.
Cheers
Yeah that was max range. I didn't press it that far except 1 time in Oklahoma. Typically I would stop at 130 at 140 mile intervals. I dont have the Average watt/mi from the trip. I will note that down on our next adventure. Overall a really great car to tow a small trailer with.170-180 seems pretty darn good towing a trailer.
Good luck, sounds like fun! Let us know how it goes....Hello all, newbie MY LR owner here with OEM tow hitch (took delivery a month ago).
After reading this and many other threads, I decided I will do my NYC to Woodland Hills, CA move with an enclosed 5x8 U-Haul trailer almost fully loaded.
I am using U-hauls official starter kit and the 7 to 4 light adapter.
Here's some tips I've collected so far:
1. Keeping it at 55-60mph is key
2. Using ABRP it's making me going through the North side of the map (it seems more chargers per mileage) so would have to deal with those winds/cold
3. Be ready to unhook on some stations (hopefully not many!)
4. I am not going over 100 miles per each segment without a charge (just to be on the safe side) expecting 450 to 500 wh/m
5. Buy a good lock
This is taking me 6 nights and 7 days,
If you guys have any other tips or tricks to maximize that range or if you want to hear back from the results, please let me know,
Wish me luck!
Definitely will be interested to hear your actual results after your trip compared to your assumptions - which sound pretty reasonable to me.Hello all, newbie MY LR owner here with OEM tow hitch (took delivery a month ago).
5. Buy a good lock
Wish me luck!
Good point, I am trying to follow what ABRP gave me (I did input my extra weight and expected wh/m), which is an avg of 10/70... there are a couple of exceptions due to distances where is making me go to 100%, particularly the in Green River, UT station to Richfield, UT station.Definitely will be interested to hear your actual results after your trip compared to your assumptions - which sound pretty reasonable to me.
Would also like to hear what charging ranges you typically end up doing/needing (i.e. 10%-80, 20-90, etc) on your charging stops as you go along. Due to charging time we tend to target arriving to charge at around 5-10%, and only ever charge to 70-80% (with no trailer) just because of the speed of charging is so much faster below 70-80%, will be interesting to know if you end up needing to wait longer and always charge higher to 90-100% for instance to get to each next charging stop or whether you can apply a similar 10-80% charging approach by stopping every 100 miles.
I thought that it the camera were blocked that you could not activate Autopilot...Depending on how wide your trailer is, the car may mistake it for a large truck and ghost break while cruise control is on. Since autopilot is not allowed in tow mode, we just cover each of the lower side cameras with tape so the car does not “see” the trailer and ghost brake. Good luck!
Sorry to bump this old post but I have a 13-foot Scamp and a new Model Y! If you don't mind some questions:The MY LR towed the 16ft scamp very well from the factory in Minn back home to Texas. We were able to get 170 -180 mi per charge but noramally stopped more frequently. I was keeping the speed at 60. So basically was hitting every super charger sort of do that anyway, just with the trailer I charge to 90 ~ 95 instead of the 75 ~80 w/o a trailer, and would come in around 10~15 %. Anyway it works great the free charge from the RV campground. Scamp is a fantastic little travel trailer and pretty aerodynamic. It isnt wider than the car, anyway if someone is looking for a travel trailer for the Y...I would recommend the Scamp.
Cheers
1. Depends on your trailer. I know you said Scamp, but there are some details people would need to know first. Basically you want to get the trailer as level as possible, within some limits. And get whatever ball size you need for your trailer. (will be one of two sizes)Sorry to bump this old post but I have a 13-foot Scamp and a new Model Y! If you don't mind some questions:
1. What hitch and ball?
2. Which brake controller?
3. What adapter or extension cord did you plug the Tesla in at the campground? Did you use 50-amp service?
Thanks!
Also, considering that there is a ball rise limit on the Y of 0.75", you may run into difficulty trying to level your Scamp unless it just so happens to line up with the Model Y height.
In addition to @HyperionMark's great advice above, I'd add that a 14-50 extension cord is really helpful at campsites since the Tesla UMC often isn't long enough to reach without some awkward positioning. I always carry mine and run the extension under the camper. It also makes the car charging less obvious, which shouldn't be necessary but does limit the attention you might get about charging while camping. I've had a few unfriendly comments about it in the past.
The vast majority of the time, I have had only positive comments and discussions. However, I have had a couple of campground operators and camp hosts say things that were not very welcoming of my EV charging. I was once told at an Oregon State Park that I couldn't charge from the pedestal. I got in touch with OSP when I got home and have a letter stating that the power is available for "any use" so long as I'm renting the space. I keep a copy of that with me. I also had a private campground operator ask how much it is costing him to have me plugged in. I tried to explain how the Class A next to me with two ACs running nonstop in the 90 degree heat was potentially drawing similar current, and even offered a few extra bucks. He grumbled and walked off.Unfriendly comments from the campground operators, or just random jerks?
