Hello Tesla People!
I've been hunting high and low for this. Like many of you I've ordered an aftermarket EcoHitch for my Model Y and am happy to work through the installation on my own.
Re: a wiring harness, I have not found any 7-pin connector solutions and also can not see a reasonable way to tow a 3,000lb camper trailer without also adding a proper brake controller which needs a brake signal.
I found this Tesla part for the Model X that plugs directly into the connector on the bumper and provides the 7-pin connector.
1046032-00-C
Does anyone know if this is the same part / wiring for the Model Y? It seems that adding this and mounting along with the hitch assembly would be ideal. I will then supplement with a brake controller using the 4-pin connector up under the dash.
Any advice appreciated (minus "go spend $1200 on the OEM hitch").
Thank you in advance!
1046032-00-C
