Model Y vs Mustang Mach E
Discussion in 'Model Y' started by Radish11, Jan 24, 2021.
Is the $7500 tax credit worth waiting months to get Mach E instead of Model Y?
  1. Yes
    25 vote(s)
    16.4%
  2. No
    127 vote(s)
    83.6%
  1. Teledatageek
    Teledatageek Member
    Rochester, NY
    That's what I do now with the quick push of the button. Annoying though.
  2. Teledatageek
    Teledatageek Member
    Rochester, NY
    I have had good luck with the system on my current and past Fords (Explorers, Mustang and Raptors). If anything it can be too aggressive.
  3. jcanoe
    jcanoe Active Member
    Maryland
    Good to hear. My Ford Fusion was a 2011.
  4. hacer
    hacer Active Member
    Clarksville, MD
    Those conditions should not make very much difference on your range. Was there rain or snow involved? Hi winds perhaps? Is your tire pressure low? Something or other was not right.
    Both my S and my 3 would see less than a 10% range reduction in these conditions on a highway drive and neither of them has a heat pump. Driving around town with multiple stops would be a different story (more range reduction due to cold and limited regen) but those are usually short range anyway so it doesn't matter.
  5. Teledatageek
    Teledatageek Member
    Rochester, NY
    It was clear - might have been a bit of wind, which is fairly standard this time of year. Tire pressure at 42. Radio on, seat heaters typically on the 2nd level. The range drop we have experienced has been pretty consistent with multiple trips taken.
  6. hacer
    hacer Active Member
    Clarksville, MD
    I always use 45 psi pressure but that's not very different from 42. Did you check the pressure at the cold temperature? Both my cars are lower profile than the Y so maybe it's just that much worse with the higher air density at cold temperatures for the taller vehicle. Seems surprising to me. If that (extra drag due to air density) is the culprit, one strategy that could help is drafting behind a larger vehicle - even at 5 car lengths behind it can be quite helpful at 70 MPH.
  7. Teledatageek
    Teledatageek Member
    Rochester, NY
    Yes, checked pressure when the temps got colder and before driving. I don't do this daily of course but am pretty confident with the current PSI in the tires. Thanks for the tip - we'lll keep experimenting. All new to us....
  8. laservet
    laservet Member
    Williamsburg, Virginia
    Since the AI is constantly working on the autosense it should improve over time.
  9. laservet
    laservet Member
    If you say "wipers on low" it works just fine, don't need to say "windshield" at all, just tried it again to make sure I was remembering correctly. Same with "wipers off," "wipers on medium" and "wipers on high."
  10. TLLMRRJ
    TLLMRRJ Active Member
    Houston
    "Should" is the operative word. How many millions/billions of miles of data collected for the AI to do it thing over the last 5 years? It still stinks.
  11. pt19713
    pt19713 Member
    Delaware
    The same engineer that designed the wipers probably worked on the scheduled departure (which sucks, too)
  12. jcanoe
    Maryland
    They also had a hand in the design of the latest vehicle status screen.
  13. laservet
    laservet Member
    Seems to be pretty functional to me. What specifically do you find it lacks?
  14. TLLMRRJ
    Houston
    The ability to not stink, like many have pointed out. Things like it not wiping when the windshield is covered in raindrops and you can't see out of it need to be fixed -- and wiping at full speed when there's only a light drizzle on the windshield.
    I am glad you think it's ok. That makes it easier for you and Tesla.
  15. pt19713
    pt19713 Member
    Delaware
    I've driven in rain, can't see out the window, yet the wiper doesn't activate. Plenty of others have mentioned how bad the auto wipers are, so we aren't the only ones. I've given up on the auto control, but even the low speed is a bit fast for some situations, so I end up doing the quick mist.
  16. Needsdecaf
    Needsdecaf Member
    The Woodlands, TX
    Agree with all of this. The auto function sucks.
    Don't forget the scenario where the wipers constantly wipe a dry windshield because they left a little residue over the camera when clearing it. Great for wiper longevity!
  17. Rocketir
    Rocketir Member
    Rocklin, CA
    Big Ford Fan. Contemplated waiting for the Mach E but the Model Y was ready and proven. Also the supercharger network was a big deal as I make long road trips. Plus it was the wifes car and she didn't want another "Mustang".
    I can't believe we haven't talked about the Mach E 1400. Great advertising, or something...
  18. Teledatageek
    Teledatageek Member
    Rochester, NY
    Sounds exactly like me. But here I am 3+ months in looking really hard at switching to an MME. The Y's shortcomings are starting to drive me crazy. I don't have the road trip need that you do though - we'll just take the Raptor. :)
  19. Radish11
    Radish11 Member
    Usa
    Thank you all very much for all the info and to everyone who posted.
    Got to test drive a Mach-E on Thursday, placed my order for one today. First time ever driving an EV, incredible vehicle, it did not disappoint. Am sure the Model y would’ve been a great choice too. Will certainly never buy another ICE car :)
  20. Radish11
    Radish11 Member
    Usa
    Also if anyone is curious dealer said it would only be about a 16 week wait, so sounds like they are working through their order backlog quickly!
