It doesn't qualify the statement with any mention of temps. It just said more regen, and I am getting less now.
I was driving when it was 54 degrees out, but temps got as low as 40 degrees overnight while the car was parked in my driveway.
I am used to other EVs where regen typically isn't limited unless temps get below freezing.
I do expect some regen limitation at really cold temps, but this didn't seem cold enough to me to limit it so much.
Now in the afternoon with ambient temps at 60 degree, I am no longer seeing any dots and regen is back to normal/full again.
I didn't do much driving, the car just sat for the past couple hours before I headed off to lunch.
That does not appear to be the case. It is acting "normal" after just sitting in ~55-60 degrees for a few hours.
I wish I had more regen in the mornings. I didn't expect it to be this limited.
Your nice chart fits perfectly with why you saw so many dots by 10AM. It was near 40F for 6 hours. Battery isn't gonna heat up ambiently that quick from a 10F delta. Battery might have been 42F by 10AM. Also how warm was the battery when you parked it? How long ago was it parked?
It's a lot of mass, that doesn't move quickly. And takes a fair amount of energy to move it.
Even with Regen absent or reduced I'm still getting decent kwh/mi
When it was 60-70F I was getting 230-ish wh/mi now I'm getting 250-260 wh/mi (still very good).
This is on a Performance with 18" Aero's. I just put snows on, so I expect it will drop a little from that too.
