So I got 42.2.1 firmware advertising more regen power:
But in practice, on my morning commute, I am now getting lots of regen power restricted "dots" on the regen meter, and it is giving me noticeably less regen than before.
( And it isn't even that cold. My outside temp was showing 54 degree this morning. )
More or less dots has nothing todo with "more regenerative braking" in version 42.2.
It didn't say more or less regenerative braking with a COLD battery. It said more regenerative braking (meaning when it's fully warmed up).
Also CURRENT ambient temperature by morning has little to do with it. What was the over night temp? And how long was it low?
If you have that many dots, your battery is pretty COLD, pure an simple and takes a LOT of driving to warm it up. I have had dots showing for 50 miles of driving when it's 40F out. Am I freaking out, absolutely not, I fully expected it.
Your car probably won't see a NORMAL full day of operation until the temperatures STAY above 50F for 24 hours.
Let the battery manage itself.
All threads and complaints are just gonna drive Tesla to HIDE more stuff.
Your car is running fine.
At what I've seen with temps between 30-40F, I'm sure there will be WEEKS we don't see full regen when it gets down to single digits. And you won't be able to drive it into regen at all. I'm getting close to that already. Drove 50 miles at 32F and still had dots. And once the dots were gone the supercharger would not go over 50kW because it knows the battery is still to cold.
Between Winter tire changes, temps dropping, software changing and lots of new users; folks are pointing fingers at stuff you simply cannot conclude until you have conditions that CAN do full regen. Anything that exposes battery to below 50F over the past 24 hours could affect the system. It's a ton a mass to warm up. And just normal highway driving doesn't generate all that much heat. If it did, it would be normally to much waste and we've never see the ranges we have. The system is designed to not create unnecessary heat.
There is TONS of info about how EV's are less efficient when it gets cold. You did do you homework before slapping down $60-$80K didn't you?
One thing I sure wish Tesla would show is what is the coolant temp. That would help give a clearer picture of why the car behaves the way it does. I suspect we could probably calibrate the number of dots to the coolant temperature
